Moving stock from one company to another in Pastel
Yes - Select File - Export/Import and select export inventory items. Check where you are saving the file and give it a name. In the select items block, make the relevant selections or leave as blank and zzzzzz to export all items. In your second database, slect the import inventory items, choose the file and process. If you have inventory groups setup in your first company, you will need to ensure you have the same groups in the second one for the import to work.
