Discount on Pastel Invoices
  • Annelise
    • Oct 2016
    • 6
    [Question] Discount on Pastel Invoices
    Good day
    Currently my Customer invoices show Disc %. Is it possible to Change it to a R value?
    tx
  • Kevin Smith
    • Aug 2018
    • 262
    Hi Annelise
    You can change the invoice layout to give you "Unit price before discount" and "Unit Price after discount", but I can't find a database field for line item discount amount in the forms designer, so I think the answer is no. Maybe someone else has a solution.
    If you wanted to change as per the above, you would use "Line Item Unit Price" and "Line Item Nett Amount Per Unit" fields from forms designer. You could also leave the discount% field between them on the invoice.
    Kevin Smith
    KS Consulting
    www.ksconsulting.co.za
    • Jillikins
      • Dec 2015
      • 19
      Good day,
      I would like to introduce rounding onto my invoices. In other words the balance owing will be rounded down to the nearest 10. How can I show this on the invoice and to which ledger account do I send the amount rounded?
      Regards
      • Jillikins
        • Dec 2015
        • 19
        Originally posted by Annelise
        Good day
        tx
        I picked up that on our invoices we show the %-age and amount. The database field used for the amount is "Overall Discount Amount". This can be changed on the Forms Designer. Hope my comment is applicable.
        • Kevin Smith
          • Aug 2018
          • 262
          Go into Setup - Customer Control. There is a rounding Tab. Select round Down, choose the GL account you want to send the rounding to (either create expense account/COS account for rounding) and select round to the nearest 10. The last line on the invoice when printed will show the GL account and the rounding amount.
          Kevin Smith
          KS Consulting
          • Jillikins
            • Dec 2015
            • 19
            Thank you Keith. Any specific GL account or any number as long as it is an expense
            • Kevin Smith
              • Aug 2018
              • 262
              Yes. You can create a Rounding account in the GL. It would either be an expense, or a Cost of Sales account, depending on how you want it reflected in the Income Statement. Due to the fact that the discount is processed at time of sale, I would suggest treating it as a cost of sales account.
              Kevin Smith
              KS Consulting
