Perhaps try to narrow some of the other columns in order to give yourself more space to widen the Description column even more. Make sure that none of the column boundaries overlap each other.
If you are using the long form of the date format (DD/MM/YYYY), I suggest changing it to the short form (DD/MM/YY). That will allow you to narrow the Date column.
If you still do not come right, send me a PM or email me and we can look at other options on how I can assist.
I have the same problem, I had no idea it has anything to do with width of columns because it is a vertical problem.
My guess is something is wrong with the update to 15 percent vat.
Since then I am importing my statement into Excell and fixing it there.
It probably is caused by the column width being too narrow, thereby causing the details on the column to wrap onto the next line, resulting in the details to extend too far vertically.
