Pastel 18 Partner - Advanced Search - Some information
  • kevvie
    • May 2014
    • 32
    [Question] Pastel 18 Partner - Advanced Search - Some information
    Hi everyone, for those seeking some info on the function, here is what I have experienced so far.
    Pastel added Advanced Search to the Inventory. What a very nice function, especially if you have many of the same items to search for which comes in different makes and models), However, there is a lot of work for them to consider fixing and adding.
    1. When you do a GRN - you can not add an item directly, nor can you edit an existing item. (same with Customer Processing).
    2. When you use the advance search - users cannot disable this function except in sole access mode. This should be changed to give the user the option themselves without sole access.
    2A - Stock on hand does not show in the same row at all, there is no multi-store - so to click on the show store details is totally useless as it only put a + sign, then to click on each corresponding item to expand the item, I suggest that a total stock on hand is displayed on one line (Even for multi-store) - then expand it yourself to check which store has the stock on hand. however iff there is no multi-store expansion should not even be there.
    2B - however, when you use Inventory Zoom - it goes back to the normal inventory search screen. (which doesn't help whilst in Document Processing)
    3. Expand all button for multi-store.
    3A - No expand button for single store companies - it shows the stock on hand without clicking anywhere.
    4. When you do a search, the database query takes ages to load.
    I would like to hear what other users experience, maybe they can help or suggest solutions.
    I tried to explain it best I could.
    Regards, Pieter
  • ITS
    • Apr 2018
    • 6
    Hi Pieter
    Nobody here likes the "enhanced search". It take too long to load and shows less detail, such as holding quantity. How do you disable it?
    • kevvie
      • May 2014
      • 32
      You disable it somewhere in the user accounts settings. I don't have Pastel at home so can't recall clearly.
      I have found its very useful as I said previously if you have to search for a. Word or string of words, however the rest is useless.
