How to 'print' individual pdf statements for each customer from Pastel Partner 14?
[Question]
Hi All,
How to 'print' individual pdf statements for each customer from Pastel Partner 14? In other words I would like to have individual pdf statements for each customer selected in a range.
Does anyone have the answer to this question?
g
As you have probably discovered, if you print a range of customer statements as PDF, the system will produce a multi-page PDF document containing each customer's statement in a single PDF file.
My suggestion is to download and install the free PDFill utility from https://www.pdfill.com which you can then use to split up the Pastel produced PDF file into multiple PDF files.
Thanks Neville! Not really the answer I was hoping for but will have to make do with the compromise solution.
Why don't you simply select the email option which then send a separate PDF statement to each customer?
Hi Neville,
I simply wanted a way to reconcile which had been sent and which had not. In the end I simply reconciled against the 'sent items' in my email client.
Thanks for your help.
g
