Pastel Run-time error 482
  • Marietjie Wilkinson
    • Dec 2016
    hi, i am marietjie. I am a bookkeeper. I work on pastel.
    I have a problem with pastel 12. Can anybody help.
    when i try and print the invoice the following message appear.
    Run-time error '482':
    printer error
    Would love to hear from any of you.
  • SHUGGA
    • Mar 2017
    • 3
    Hi Marietjie
    I'm having the same problem. Were you able to find a solution?
    • UniquelyJanine
      • Mar 2017
      • 40
      Under File Printer fonts setup click on the set printer button and select the printer you are using. Click copy to all tabs and click copy to all users.
      If this doesn't work please let me know.
      • SHUGGA
        • Mar 2017
        • 3
        Thanks very much for responding.
        Managed to sort out the problem. Windows 10 had done an auto update and changed my dot matrix printer driver. Once I had reinstalled the driver, error message disappeared and all running smoothly.
        Thanks goodness.
        • LizaC
          • Sep 2017
          • 13
          Please assist I have the same error and can not print my pasylips
          Pastel Run-time error 482 - I uninstalled some print drivers recently and after I did that all went wrong....PLEASE assist...rather urgent. White Drives do i need??
          • Kevin Smith
            • Aug 2018
            • 262
            In Payroll - go to File - Printer Font Setup - Go to the Payslips Tab - click set printer - choose your active printer and click ok. You will probably also need to change your report printer in payroll as well.
            Kevin Smith
            KS Consulting
            www.ksconsulting.co.za
