Importing Inventory Master files into Pastel Partner
  • David Irish
    • Jun 2016
    • 13
    [Question] Importing Inventory Master files into Pastel Partner
    Hi there
    I'm trying to bulk block a whole lot of inventory items.
    I've exported the inventory masterfiles; opened in excel; changed the Blocked field from N to Y and then saved as csv and tried to re-import.
    Both the export and import is with column headings.
    Nothing happens!
    The Export/Import window just says "0 inventory records successfully imported."
    I've attached a sample of 2 lines of the csv file.
    Can anyone see anything wrong with the formatting of the file or knows of any idiosyncrasies with the process I should be aware of?
  • David Irish
    • Jun 2016
    • 13
    Don't worry folks; I sorted it out.
    • nelka
      • Aug 2017
      Hi David
      Please tell me how you sorted this problem? I have the same problem!
