Pastel - POs and Supplier invoices
  • TravisZA
    • Sep 2014
    • 108
    Hi,
    I'm having trouble linking a PO to a supplier invoice. When I select the PO the checkboxes next to each line item are unselectable.
    Anyone had this issue before?
    Not sure if its because they are inventory items or what the story is????
  • AddiG
    • Nov 2015
    Hi Travis,
    Have the goods been receipted?
    You must link the goods receipt to the PO then Invoice to Goods Receipt
    • TravisZA
      • Sep 2014
      • 108
      Oh ok. They havent been receipted but I'll do that and try again.
      Thanks.
      • TravisZA
        • Sep 2014
        • 108
        Originally posted by AddiG
        Hi Travis,
        My issues continue....I linked a GRN and then the invoice - now where is the cost sitting? I can't see it under COS? But it does appear in the project IS - makes no sense.
        • CLIVE-TRIANGLE
          • Mar 2012
          • 886
          I don't know Pastel at all, but should the cost not be sitting in inventory?
          It only gets to COS when sold.
          • Neville Bailey
            • 2786
            Clive is correct.
            When you process the GRN / Supplier Invoice, the Inventory Control Account is debited and the Supplier Account is credited. When you sell the stock by means of a Customer Invoice, the Sales Account is credited, the Customer Account is debited, the COS Account is debited and the Inventory Control Account is credited.
            • TravisZA
              • Sep 2014
              • 108
              Hi Neville, is this also true for service inventory items?
              • Neville Bailey
                • 2786
                No, there is no physical inventory involved, so you won't be processing Purchase Orders, GRNs or Supplier Invoices for service inventory items.
                You will only use service inventory items when processing Customer Invoices, in which case only Sales will be credited and Customers will be debited. There is no COS in this case.
                • Tarynfm
                  • May 2018
                  Hi Neville, regarding converting PO to supplier acct , when the P.O. has an inventory item, it’s not pulling the inventory item through. Why is that?
                  I am not entirely understanding the the goods receipting concept. Can one not pull the P.O. straight to a suppliers invoice?
                  • Neville Bailey
                    • 2786
                    The PO has no impact on the accounting records and does not update stock quantity on hand - it is merely a tracking document.
                    If you have GRN's enabled (go to Setup...Suppliers...Control to check), then stock will be brought into the system by means of a GRN. If you don't have GRN's enabled, then stock will be brought into the system by means of a Supplier Invoice.
                    From what you have described, you have GRN's enabled.
                    You need to link the PO to a GRN, which will then bring the stock in, then link the GRN to a Supplier Invoice in order to update the Supplier account.
