The Quantity in a pastel invoice print over 2 lines because the Quantity is like 120 000. Can I fix it that it can print in One line
Change Quantity Field Size in Pastel
Tags: None
Hi JP, you can but this will require venturing into forms designer which could be pretty overwhelming if you've never worked in it before, but is a simple process if you have.
If you have, open the layout and widen the Quantity field in the same manner you would resize an object in any office application by clicking on a resizing handle and dragging it left. You need to be careful as sometimes if one field overlaps another (not all the time), it can push the entire alignment of your form out. You'll need to move any fields to the left of the Quantity field over to the left if this is the case.
In short, if you've not worked with forms designer it's best to get someone who knows their way around to assist you.Opportunity does not knock. It presents itself when you beat down the door.
