Applying discount after invoice - Pastel
  • Raene
    • Nov 2012
    • 43
    Hi there
    I am trying to figure out the best way to apply discount after an invoice as been updated on Pastel. Do I put through a journal to credit the discount amount (with or without vat) or a credit note?
    Thanks for your help in advance.
    Regards
    Raene
  • Neville Bailey
    • 2786
    I presume you are referring to trade discount rather than settlement discount.
    I think the credit note option is the better one, as you would need to debit sales and VAT.
    • Raene
      • Nov 2012
      • 43
      Hi Neville
      In this case it would be a trade discount. How would it differ in terms of a settlement discount if it were not setup on Pastel?
      Thank you
      Raene
      • Neville Bailey
        • 2786
        A trade discount is essentially a price adjustment, so it would effect sales.
        On the other hand, a settlement discount is a conditional discount, which is only applied at the time the payment is received, and results in a debit to an expense account called Discount Allowed.
        • Raene
          • Nov 2012
          • 43
          The invoice was issued in March and paid in April and the customer took their discount. The discount wasn't applied so there is an amount on the customers account reflecting as overdue. This amount needs to be put through as a trade discount. I am not sure how to do this using a credit note as the credit note opens inventory codes instead of a GL account. Do I apply the amounts to the individual inventory items as per the original invoice?
          I haven't worked with discounts before so I am really lost.
          • Neville Bailey
            • 2786
            When processing the credit note, change the line type from 4 (Item Code) to 6 (GL Code) and use the sales account. You need to apply VAT as well.
            • Raene
              • Nov 2012
              • 43
              Thanks Neville, but that is the problem. It doesn't give me the option to change the line type.
              • Neville Bailey
                • 2786
                Then it means that your user access settings need to be changed.
                Log on with a supervisor password, and then go to Setup...Users/Passwords...Users.
                Browse to your user name and select it.
                Click on the "Process Options" button on the right.
                Under the "Customers" section, scroll down to the option "Can Process GL Lines on Documents" and tick it.
                • Raene
                  • Nov 2012
                  • 43
                  Neville, for the settlement discount that wasn't processed, do I also create a credit note but instead allocate it to the discount allowed GL account? Or is a Journal more appropriate?
                  • Neville Bailey
                    • 2786
                    A customer journal would be fine for processing settlement discounts.
