Inventory journal entry on Pastel
  • Jackievdw
    • Jun 2012
    • 6
    [Question] Inventory journal entry on Pastel
    Good morning
    Please can someone advise me why after I captured an inventory journal, the amount reflected on the trial balance differs from the actual amount I processed.
    Thank you
  • Elijah
    • May 2012
    • 129
    Hi Jackie
    Are you using the Inventory journal for corrections or to capture your inventory purchases?
    • Jackievdw
      • Jun 2012
      • 6
      Originally posted by Elijah
      Hi Jackie
      Hi.
      I used it for corrections
      • Elijah
        • May 2012
        • 129
        Hi Jackie
        Those not well acquainted with Pastel usually dont know that this is only for Adjusting inventory prices and quantities. If your answered had being different, then I would have said this is most likely the root of your problem. Maybe a bit more back-ground into how your stock is managed would allow me to consider other options. For instance are you using perpertual or periodic inventory, and the reason why you using either option.
        • Elijah
          • May 2012
          • 129
          Is your business Stock intensive?
          Are you using a POS?
          When did the problem start, which Vat Period?
          • Jackievdw
            • Jun 2012
            • 6
            Good morning
            Thank you for your help so far.
            We buy and sell motor vehicle parts and have only just started using pos in April. This problem occurred when we did stock take at year end in Feb and we realised that we had to adjust certain stock items due to either stock missing or too much stock. I printed the inventory journal entries before updating, so we know exactly what amount we put through, yet this differs on the trial balance. Someone mentioned something about cumulative totals and not sure what they mean
