Advance search
  • league_of_ordinary_men
    • May 2012
    • 428
    Advance search
    There's something wrong with the advance search, there's two errors on lines 261 Warning: Declaration of vBForum_Item_SocialGroupMessage::getLoadQuery and 337 Warning: Declaration of vBForum_Item_SocialGroupDiscussion::getLoadQuery.
    • 22803
    Did some tinkering and managed to reproduce the problem. Thanks for the heads up.
    Fortunately it seems only Group discussion items are affected (by being omitted from the search results). Everything else seems to work just fine.
    I'll pass it onto vBulletin to resolve in their next update (if they're not aware of the bug already).
    • Basment Dweller
      • Aug 2014
      • 314
      I'm still getting this problem (search failing), the following text is appearing at the top of the forum after attempting a search:
      Warning: Declaration of vBForum_Item_SocialGroupMessage::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/item/socialgroupmessage.php on line 261
      Warning: Declaration of vBForum_Item_SocialGroupDiscussion::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/item/socialgroupdiscussion.php on line 337
        It's a known vbulletin issue. Nothing to worry about it's just displaying/parsing php error messages that are normally only written into logs.
