Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Starting capacitor
    Gold Member Martinco's Avatar
    Oct 2008
    Rustenburg
    Starting capacitor
    I have a problem whereby the starting capacitor of a pump motor packed up and I need to replace this.
    Specs: 14 Mfd at 400V. I can only locate a 10 Mfd or a 20 Mfd capacitor. Which would be the better replacement and why ?
    Martin Coetzee
    www.straptite.com
    You may never know what results will come from your actions, but if you do nothing, there will be no results... Rudy Malan † 05/03/2011
    Not knowing the application, and making a call like this may be risky. If you do a few starts a day, then use the 20MfD. The higher the capacitance value, the higher current that flows, and the motor will have more starting torque.
    The period in which the start capacitor remains in the circuit is a second or so, so the extra current flowing will not cause any harm.
    However if this motor starts many times an hour, I would suggest you get the correct one. Using the lower capacitance may draw less current in the start winding, but it may also cause the motor to stall due to torque loss, which could cause a burn out.
    Martinco (06-Dec-10)
  4. #3
    Oct 2008
    Rustenburg
    Many thanks, The motor only starts once a day so the 20 MfD would be fine.
    Martin Coetzee
    www.straptite.com
  5. #4
    If there is only one cap and it's rated at 400v discharge voltage then it's most likely a run capacitor and not a start capacitor.
    Use a clamp meter on the pump whilst under load and pick the capacitor that gives you the lowest running current. You should be able to find a 15ยตF - 400v cap if you shop around.
    Martinco (07-Dec-10)
  7. #5
    Oct 2007
    this sounds like a pool pump motor?
    what size is the pump motor?
    what is the application...if it is a pool pump motor i can only assume you think the cap has gone because the motor makes a humming sound when you try start it?
  9. #6
    Oct 2008
    Rustenburg
    Hi Murdock, Andy
    Actually a jacuzzi pump motor @ 1/4 hp and yes, it made a humming sound when trying to start. If you spin it by hand it does start and runs fine.
    I have put the 20 Mfd cap in and the motor starts 100% and still runs cool. ( I left it running for +- 30 min.)
    So, the problem has been canned and my wife can enjoy her jacuzzi again.
    Martin Coetzee
    www.straptite.com
  10. #7
    Oct 2007
    next step...trade test and you are smokin
  11. #8
    Oct 2008
    Rustenburg
    Hmmmmmmm, by looking at your threads/posts, I am not so sure !
    Martin Coetzee
    www.straptite.com
  12. #9
    Oct 2007
    my apologies if you feel i am targeting you...it is not my intention.
    after reading the post again i can see why you would think so
    i can ask dave to remove it... unfortunelty the 20 minutes is up so i cant edit.
    by the way i am happy with my wife and dont have any desire to look at other peoples wives.
  13. #10
    Oct 2008
    Rustenburg
    Hey Dude, I am pulling your leg !
    No offence taken.
    Martin Coetzee
    www.straptite.com
  1. [Question] Starting an office equipment leasing company
    By Amartin in forum General Business Forum
    Last Post: 13-Sep-10, 11:31 PM
  2. [Article] Starting your own online business Stage 1
    By Chatmaster in forum Marketing Forum
    Last Post: 13-Nov-09, 03:39 PM
  3. [Article] Starting an online business
    Last Post: 08-Nov-09, 06:47 PM
  4. Next step: Business starting
    By Snoopy_inc in forum Entrepreneurship and Business Management Forum
    Last Post: 24-Jul-07, 09:58 PM
  5. are the BEE cracks starting to show?
    By duncan drennan in forum BEE and Employment Equity Forum
    Last Post: 27-Nov-06, 10:28 AM
