Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Cloning Hard Drive
    Platinum Member AmithS's Avatar
    Oct 2008
    Cloning Hard Drive
    Hi All,
    So say i get a new laptop & i want to save the original installation as is in case something happens.
    What is the best way to clone the original hard drive so that i would be easy to reinstall the entire clone onto the same hard drive but with the original software if i want a fresh start on the laptop (i.e. basic setup)
    Regards,
    Gold Member daveob's Avatar
    Feb 2008
    Amanzimtoti
    Personally I have used Norton Ghost for that.
    Can't say it is the best, it's just all I have used.
    Did the OS install, all drivers, office, net setups, etc, then made the copy.
    Only ever used it once to reset my PC, but that one time it was a BIG time saver.
    You can try clonezilla, it's freeware available from here. http://www.clonezilla.org/
    Also I think GParted will do a restore partition, also freeware here. http://gparted.sourceforge.net/index.php
    Acronis True Image is another alternative which you will pay for but I think they have trial versions if you want to test drive it first.
    Gold Member Martinco's Avatar
    Oct 2008
    Rustenburg
    I stand to be corrected but you would need the following:
    Norton Ghost with USB support and then a USB to SATA hardware interface with a power adapter to do a clone via USB because the laptop does not have facility for another internal drive, so you cannot simply plug the clone drive into the laptop, you have to go USB.
    These interfaces are available at computer shops and are not expensive.
    Martin Coetzee
    www.straptite.com
    Why not just use the MS "create repair disk" option?
    Oct 2008
    Rustenburg
    Are you sure ? On a laptop you have all sorts of drivers for pad, monitor etc. etc. Will the repair disc copy the drivers as well ?
    Martin Coetzee
    www.straptite.com
    As I recall, it creates a full mirror of the drive.
    Obviously when it comes to maintaining the current status of a drive in a backup, ghosting the drive is the answer. But if you're looking for a copy of that early clean install before any bugs crawl in, the repair disk creation tool might just be the answer you're looking for.
    Best done on an external hard drive though - even with the high capacity of DVD disks nowadays, you'll be looking at quite a few disks to get the job done.
    Diamond Member tec0's Avatar
    Jun 2009
    daveob > You are right, Ghost works.
    Depending on your version, ghost will give you the ability to clone your drive onto another drive and or make an image that you can cut do disk “provided it is small enough” and you can reuse it over and over again “until the disk is unusable or corrupted”
    From my personal experience I can say Ghost is stable and will do the job. But I am sure there will be people that will tell you that ghost sucks and that I am stupid...
  9. #9
    Gold Member twinscythe12332's Avatar
    Jan 2007
    durban
    Quote Originally Posted by tec0 View Post
    hehehe, my friend made a ghost of his main hard drive onto a 1TB drive... this promptly turned it from a 1TB drive to a 32MB drive. formatting did not revert, neither did looking at any of the disc managers. Matrix is still puzzling about how it happened, and has given him a new 1TB. Ghost is good, but when it messes up, it takes hardware with it.
    as for the original question, I would say you can safely use the windows backup facility. It has worked well for me, and is already included in the package (depending, of course, on which windows you have. I am assuming either vista or windows 7).
    Should using a microsoft product on your current windows installation (theories go that using a microsoft product on more than two tiers will cause a black hole in your machine, and destroy your data irrepairably) not ease your mind, the above solutions will also work =)
    Last edited by twinscythe12332; 01-Oct-10 at 02:01 PM. Reason: messed up some spelling
  10. #10
    Oct 2008
    Rustenburg
    JFMI Was this an external or internal drive and what make ?
    Martin Coetzee
    www.straptite.com
  1. Telkom Hard Capping
    By popayetwo in forum Technology Forum
    Last Post: 21-Aug-09, 03:02 PM
  2. Can Hard Work Turn You Into A Billionaire?
    By sgafc in forum General Business Forum
    Last Post: 30-Apr-09, 03:12 PM
  3. strange hard drive noises
    By gecko in forum Technology Forum
    Last Post: 08-Nov-08, 12:48 PM
  4. Over 8000 cops can't drive yet
    By Eugene in forum General Chat Forum
    Last Post: 16-Aug-07, 04:29 PM
