Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: PV Suppliers?
    Gold Member Sparks's Avatar
    Dec 2009
    PV Suppliers?
    Hi guys, does anyone know who stocks 16 and 25mm PV cables? Inverter max capacity is 80A and I will have 68A to connect between combiner box and inverter. A single cable from the combiner box inverter isolator will be neater than having all my strings cables in bigger trunking.
    Mar 2022
    You dont need to use PV cables between the combiner and the inverter, the PV cables are double insulated for use on the roof.
    Just make sure the cable is suitable for the DC voltage.
    Dec 2009
    Thank you Isetech, I did consider that but would like to use fire retardent cables if possible, the batteries and inverter are just below and should anything untoward occur, at least I would have tried limiting more damage. As it is, the terminals on the inverter were not exactly designed for 25mm cables which would be the correct size for 80A DC
    Mar 2022
    IF you are concerned about fire, I hope you are not using PVC trunking as most domestic installations are done, I would be using metal trunking (P8 or 9000). Please tell me you combiner box is also metal, I hear all this talk about fires, yet 99.9% of domestic solar installations posted on social media use the dangerous home made DC PVCcontrol boxes.
    Dec 2009
    Yes, I agree, earthed metal boxes and conduit are the way to do it. I have not started the installation yet as I am first trying to get the cables I want.
    Mar 2022
    For the record its not lithium batteries bursting into flames and burning down buildings, I hear the most common cause of fires in domestic installations are the home made plastic DC control boxes, full of 'imported" Dc components supplied and fitted by installers.
    Mar 2022
    Check the manufacturers spec sheet, these cables have a much better current rating than our standard house wires.
    Most burnt connections etc I have seen are bad workmanship , strands cut off before fitting into lugs , AC equipment used in place of DC , DC CB used on batteries and the CB are not bi direction but Bi Polar and fault levels not taken into account
  9. #9
    Mar 2022
    you could add loose connections to that list.
  10. #10
    Dec 2009
    I agree with both of you, another problem is also that people store paints and chemicals in their garage. Last week I worked on an installation where they had a setup installed last year and the people thought it a good idea to store corrosives beneath the inverter. Needless to say everything is corroded and they can kiss their warranty goodbye
  1. [Question] Suppliers Invoicing
    By Saffiya in forum Accounting Forum
    Last Post: 27-May-15, 04:37 PM
  2. Motor suppliers
    By AndyD in forum Electrical Contracting Industry Forum
    Last Post: 14-Mar-13, 10:33 AM
  3. looking for cow hide suppliers
    By Niki in forum General Business Forum
    Last Post: 21-May-12, 01:36 PM
  4. [Question] Can't pay suppliers
    By Conan in forum General Business Forum
    Last Post: 22-Sep-09, 05:10 PM
