Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Electrical CoC
  1. #11
    Mar 2008
    I'm going to put what I think after each one - see what everytome else says
    Silly petty things like
    exposed wires between the terminal block, - Fail
    earthing downlights, - if metal and not earthed - fail - us SANS approved GU10 lamp holder (with earth)- don't like them but can't fail them
    exposed metal light fittings higher than 2.4 m, - fail
    cracked switches and socket outlet covers, - fail - not suitable for use
    DB's behind the fridge, - grey area - you can't stop people putting fridge over their DB - was the fridg ethere when you tested - note in commenct section
    or above the stove, - fail
    or in cupboard, - in a domestic - fine as the owner knows where to isolate if a problem - I'll lable the cupboard during CoC
    Cabtyre feeding circuits, - apparently its ok now according the new reg - haven't had to deal with it yet so haven't looked it up
    Rip cord used for security lighting from a plug top, - fail
    Transformers feeding gates motors from the garage 50 m away, - not sure i get that one?
    intercom and power cables in the same wireway, - technically, a fail
    roof spaces which look like an alarm installer wired up everything, - usually a fail after some scratching around
  2. #12
    Mar 2022
    For the record, cracked switches and plugs is not a fail, as I learnt he other day doing a COC audit. So long as you cant touch exposed wires with the standard test finger it is a pass if the cover is cracked.
    Just anotehr reason you wan the installation checked before you sign the transfer papers. Once you sign, you pay to replace the cracked covers or sockets and switches.
  1. Electrical coc for sub db
    By Courtesy00 in forum Electrical Contracting Industry Forum
    Last Post: 30-Dec-21, 11:16 AM
  2. [Question] Electrical assessor
    By Lindley in forum Electrical Contracting Industry Forum
    Last Post: 28-Feb-19, 11:33 AM
  3. [Question] DIY electrical
    Last Post: 05-Jun-11, 10:49 AM
Tags for this Thread
