Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Help with HTML code
    Silver Member Vincent's Avatar
    Oct 2007
    Edenvale
    Help with HTML code
    On a page where the HTML code is active how does one show the actual code without it converting it to the image.
    If the code is this:
    <a href="http://www.jaffyhead.com" target="_blank"><img src="http://www.jaffyhead.com/style_images/11197887682/logo4.gif"
    alt="jaffyHead.com – You're Not Alone"
    style="border:1"
    title="jaffyHead.com - a safe social & educational networking site"></a>
    and I want it to remain like this on the page, how do I go about it.
    Vincent Marino
    Maximising the sales value of your business!
    Business 24-Seven |MyBlog Twitter |facebook |Phat feesh & chips
    just me duncan drennan's Avatar
    Jun 2006
    I think the simplest way is to wrap it in the <code> </code> tags.
    There might be more advanced ways using CSS.
    [SIGPIC]Engineer Simplicity[/SIGPIC]
    Turn ideas into products | The Art of Engineering blog
    Did the code tag work, Vincent?
    If not, this the way the W3C Validator deals with the problem. They use this HTML code:
    Code:
    <pre>
          &lt;a href=&quot;http://validator.w3.org/check/referer&quot;&gt;&lt;img
              src=&quot;http://www.w3.org/Icons/valid-xhtml10&quot;
              alt=&quot;Valid XHTML 1.0!&quot; height=&quot;31&quot; width=&quot;88&quot; /&gt;&lt;/a&gt;
        &lt;/p&gt;
    </pre>
    which resolves into this on page display
    Code:
          <a href="http://validator.w3.org/check/referer"><img
              src="http://www.w3.org/Icons/valid-xhtml10"
              alt="Valid XHTML 1.0!" height="31" width="88" /></a>
    I know it looks messy, but it's less complicated than it looks. Basically you do some substituting.
    < = &lt;
    " = &quot;
    > = &gt;
    Oct 2007
    Edenvale
    < = &lt;
    " = &quot;
    > = &gt;
    I did the substitution but it still wasn't right. So I did the thing I should have done in the first place. Phoned my IT guy.
    Time wasted: Vince 2hrs
    Russell: 2 minutes
    Next time phone the professionals
    Vincent Marino
    And the right way to do it was...?
    Please let it not be NOPARSE
    I've just tested this - works perfectly:
    Code:
    <p>&lt;a href=&quot;http://www.jaffyhead.com&quot; target=&quot;_blank&quot;&gt;&lt;img src=&quot;http://www.jaffyhead.com/style_images/11197887682/logo4.gif&quot;
    alt=&quot;jaffyHead.com – You're Not Alone&quot; style=&quot;border:1&quot; title=&quot;jaffyHead.com - a
    safe social &amp; educational networking site&quot;&gt;&lt;/a&gt;</p>
    Platinum Member Chatmaster's Avatar
    Aug 2006
    Speaking of which, Vincent I had a look at your linking proposal. Do you mind if I rather link to you using a link text from my sites? If you do not mind, what would your main keyword be that you are targeting?
    Roelof Vermeulen| Project Management Experts
    Oct 2007
    Edenvale
    Quote Originally Posted by Chatmaster View Post
    No problem... key word(s) grade 10, grade 11, grade 12, education, educational networking site... something along those lines.
    Let me know when you're done.
    Vincent Marino
  9. #9
    Oct 2007
    Edenvale
    I actually have no idea... but this is what the code looks like.
    Code:
    <br/><br/>
    &lt;a href="http://www.jaffyhead.com" target="_blank"&gt;
    &lt;img src="http://www.jaffyhead.com/style_images/11197887682/logo_small.gif"
    style="border:1"
    title="jaffyHead.com - a safe social & educational networking site"&gt;&lt;/a&gt;
    <br/><br/>
    Tried it with <p>, but it wasn't picking up <p>
    Guys thanks for the input, know going to try <Code>
    Vincent Marino
  10. #10
    That should produce the same results - although I had tidied out all the new lines for more compact code. Just a note on the br tag
    For HTML, the use is <br>
    For XHTML, the use is <br />
    If you are using XHTML, you should also add a trailing / at the end of the img tag.
    Not the end of the world. Browsers are very forgiving.
  1. Blogger's Code of Conduct
    Last Post: 18-Apr-07, 11:33 AM
