Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: E@syfile 6.6.3 incorrect ETI balance brought forward
    Email problem Bronwyn P's Avatar
    May 2014
    Unhappy E@syfile 6.6.3 incorrect ETI balance brought forward
    Hi All
    Last year I had no issue with e@syfile, lo and behold this year gremlins are back again
    I suddenly have a brought forward amount of the ETI starting from March 2015 (even though it has been utilised every month) I have no idea where this random pre-populated amount of R45 052 comes from as the ETI amount for the year is reflecting correctly on the first page as utilised.
    Anybody have any ideas? August submission went off without a hitch so what is the problem now?
    Dave A (25-May-16)
  3. #2
    Sep 2012
    Louis Trichardt
    HI,
    As far as I know, SARS warned at recent webinars that this will happen, but said it will be fixed in the August run. We had the same problem with all ETI clients.
    Dave A (25-May-16)
  5. #3
    May 2014
    Thank you, so I can submit as is then?
  6. #4
    Silver Member Christel's Avatar
    Feb 2012
    Hi Bronwyn, this is very weird. I have not had a single problem with any of my ETI's...BUT I have 2 data bases, one for my normal recons and one for ETI's. If you want to email me your csv file I can import it on my ETI database and see if it has the same error. If it does not have the error, I can dropbox my database to you and you can restore it on your side and submit.
    Bronwyn P (25-May-16)
  8. #5
    I had a similar problem to Bronwyn. As there was no obvious way to "fix" or "influence" the column, I ignored it and made a mental note to check on my EMPSA for 2016 in a month's time or so - as everything else balanced perfectly.
    Quote Originally Posted by dellatjie View Post
    Delighted to hear that
  10. #6
    May 2016
    CapeTown Western Cape
    Hi Bronwyn
    There was no release to fix the ETI
    You need to submit the ETI as it is via e@syFile and then print the EMP501 - Correct the figures manually and sign - date the EMP501. Send it to the SARS assessment center for correction
    I see you in Cape Town. There is regular training on e@syFile in Cape town and Bellville. You can esquire and book for training by sending an email to engagementct@sars.gov.za
  11. #7
    May 2014
    Thanks Dave I thought I'll do the same as I remember a similar problem in 2014. I emailed them the screenshots and it eventually got sorted at that time. I see though that when I go the PAYE dashboard August submission, ETI that was utilised is also showing as a difference and amount owing.
  12. #8
    May 2014
    Thanks Emjoub I don't need training on e@syfile as I've been using the software since it came out so it's not a 'user' issue. Will be lovely if the software developers of e@syfile can get it right for a few years running and fix the glitches before we need to submit the recon every year
  13. #9
    May 2014
    Thanks Christel that would be great - could you send me your email address please as I tried to private message you but no way to insert the file? Am I being dumb
  14. #10
    Unfortunately the pm system doesn't facilitate attachments.
  1. [Question] PASTEL-CASHBOOK BALANCE AND BANK STATEMENT BALANCE INCORRECT
    By Marley29 in forum Accounting Forum
    Last Post: 22-Jan-21, 09:16 AM
  2. [Question] Pastel Partner V11- conversion from open item to balance brought forward
    By MelJones in forum Accounting Forum
    Last Post: 04-Apr-16, 09:33 AM
  3. [Question] Open Item and Balance Forward conversions
    By LouisaEls in forum Accounting Forum
    Last Post: 22-Oct-15, 02:49 PM
  4. [Question] incorrect opening bank balance in pastel
    By nivashini in forum Accounting Forum
    Last Post: 20-May-15, 07:35 AM
  5. 1 Way Forward - The Way Forward In South Africa
    By adele.strydom in forum MLM Industry Forum
    Last Post: 05-May-11, 11:33 AM
Tags for this Thread
