Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Incoming/Outgoing E mail settings ?
    Mar 2013
    Had enough
    Wonder if the computer bofs can help me here please. Can you please tell me about e mail settings ?
    If you have an e mail add on your laptop at work and on your ipad. If you take your laptop home or to CT for example and connect wirelessly - most of the times your e mails will come in, but most of the time you cannot send e mails !!
    The same problem happens on my ipad, but if I change the way I send an e mail to send via my icloud address it works perfectly but is not ideal because it is not the work e mail add anymore. Can someone please tell me if I have to change the outgoing mail settings on my laptop and if so what do I change it to ??
    To be mobile, you should use your domain's SMTP server to send mail, not your ISP's.
    Assuming you're using Outlook:
    Set the outgoing mail server to your domain server's mail setting (typically mail.yourdomain or smtp.yourdomain )
    Click More Settings
    Select the Outgoing Server tab
    Check the My outgoing server (SMTP) requires authentication tick box
    Select the Use same settings as my incoming mail server radar button
    Normally that'll get you away in a "typical" hosting setup, but there may be other settings to tweak if you've got some non-default settings in there somewhere.
    If you want to send out mail over a secure connection, you'll need to get the settings from your hosting service as the name of the SMTP server for secure connections is most often not in your domain name.
    If you're using multiple devices to access the same email account, you probably want to put a bit of thought into the "when to remove messages from the server" issue in the Advanced tab.
    Mar 2013
    Had enough
    Thanks Dave I am going to check this out.
    But a question, forgive me if I'm being dof, but if you use your domains smtp like I am doing obviously from work, when I go to a wifi hotspot for example I cannot send e mails, but I can receive ?? Do I not then have to change the outgoing e mail setting ?
    Mar 2013
    Had enough
    Dave - Just had a look at my settings and our girls settings. They are as follows:
    To be mobile, you should use your domain's SMTP server to send mail, not your ISP's.- The outgoing is smtp.saix.net which is not our domain setting
    Click More Settings
    Check the My outgoing server (SMTP) requires authentication tick box - This is not ticked
    Select the Use same settings as my incoming mail server radar button - This is not ticked
    I am very hesitant to change settings as it works at work. Is there not a setting for the outgoing setting that I can just change when I use a wifi etc ?
    Mar 2010
    What exactly goes wrong when you can't send mail, what error do you get?
    I've had endless crap with error 502 Forwarding not allowed.
    The reason seems to be that sometimes when I try to send mail to my mail server in the states via the MWEB network the MWEB network refuses to connect to the mail server saying that it doesn't allow the connection across its network. It doesn't happen all the time for some reason. We never found it to be a problem with GMAIL accounts or accounts that are directly accessed over the net where you do not use a mailer like Outlook.
    We have a 50/50 change of our domain mail making it out, it does seem to come in ok though
    ~GS Elevator
    Hi HR Solutions,
    I understand your hesitancy, but nothing ventured - nothing gained
    I suggest write down the existing SMTP settings for one email account, then tinker with that one. If it doesn't work out, you can just go back to the old settings until you figure out where things have gone wrong. (There's actually very little to go wrong).
    Mar 2013
    Had enough
    Ok will give it a go.
    Adrian basically exactly as you have just said. That is what happens. G Mail is fine. I cloud is fine.
    Mar 2010
    I am unable to send email via my domain hosted in the states from my cell phone no matter what SMTP details I put in, but I can receive without a problem. I can send and receive my mweb mail via the cell phone without a problem. The exact same happens at home on my ADSL, mweb is perfect but the states based mail is up and down.
    ~GS Elevator
  9. #9
    Gold Member Chrisjan B's Avatar
    Dec 2007
    GEORGE
    The problem is that your current connection does not relay outgoing mail - you need to set the outgoing mail setting to be "compatible" with the current connection - wifi hotspot is a problem as you don't know who the ISP is....
    Here is a list of the most common Outgoing servers
    For Telkom ADSL, outgoing server is smtp.dsl.telkomsa.net or smtp.saix.net
    For Telkom Analogue Dial Up, use smtp.saix.net or smtp.dsl.telkomsa.net
    For 8TA (Eita), the outgoing server is smtp.saix.net
    For MWEB ADSL, outgoing server is smtp.mweb.co.za or smtp.mweb.net
    For Vodacom 3G, outgoing server is smtp.vodacom.co.za
    For MTN 3G, the outgoing server is mail.mtn.co.za
    For Cell C the outgoing server is mail.cmobile.co.za
    For Iburst, outgoing server is smtp.iburst.co.za
    For I.S. ADSL the outgoing server is smtp.isdsl.net
    For I.S. 3G the outgoing server is smtp.isgsm.netor smtp.dial-up.net
    For goggaconnect outgoing server is smtp.vodacom.co.za
    For Neotel, outgoing server is smtp.neomail.co.za
    For ABSA, outgoing server is smtp.absamail.co.za or mail.absa.co.za
    For @lantic (ADSL,Dialup, ISDN) : smtp.lantic.net
    For NetActive (ADSL,Dialup, ISDN) : smtp.netactive.co.za
    For Polka (ADSL,Dialup, ISDN) : smtp.polka.co.za
    For Web Africa (ADSL,Dialup, ISDN) : smtp.wa.co.za
    For Cybersmart : smtpauth2.cybersmart.co.za or smtp.cybersmart.co.za
    For Nokia/OVI : smtp.mail.ovi.com or smtp.mail.yahoo.com
    I have no solution......
    http://nellen.co.za/south-african-sm...g-mail-servers
    You may want to try the suggestion they make about using GMAIL....
    BOVER Technologies
  10. #10
    Mar 2010
    Yes and no
    This is fine when I use my mweb email address but does not work for my domain address.
    My domain address requires a pop & smtp address that is supplied by the company that hosts the domain, not by the company that happens to be the transport channel, in this case MWEB ADSL
    ~GS Elevator
  1. [Question] M C B Settings
    Last Post: 18-Apr-12, 11:27 PM
  2. The importance of e-mail and e-mail rules.
    By tec0 in forum Technology Forum
    Last Post: 16-Dec-09, 12:57 PM
