Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Importing General Ledger Journal into Pastel Xpress V 12
    Sep 2013
    Durban
    I have tried to import the attached file, and the error message I get is
    Line 1: date must be in the format DD/MM/YYYY
    Line 1: Invalid date
    Line 1: GDC field must be G, D or C.
    From what I can see, the file complies with this.
    Can anyone point out where have gone wrong please?
    import to gl.csv
    Mar 2012
    Vanderbijlpark
    Perhaps it is expecting a "," as the delimiter, as opposed to a";"?
    Stevie Mac (22-Sep-13)
  4. #3
    Sep 2013
    Durban
    Thanks for your help Clive.
    Perhaps it is because I am using Windows 8.
    Your suggestion helps me correct line 1, then I get all the same errors for lines 2-53.
    I have tried a number of things, even one a time, but I cannot get this to work.
  5. #4
    Mar 2012
    Vanderbijlpark
    Stevie, access the Windows 8 equivalent of control Panel, then Region and Language, then Additional Settings
    On the Numbers tab, change the List Seperator to a comma, the recreate that import file.
    Stevie Mac (23-Sep-13)
  7. #5
    Morningside, Durban
    Hi Stevie,
    Sorry about the delay in responding - I was too busy taking photographs over the weekend!
    Clive is correct - your CSV file format is incorrect. I have attached a sample one-line GL journal for you to look at. A tip: if you want to make sure that you use the correct format, manually create a single line entry in Pastel and then export the batch to a file, with CSV as the file extension. Also, don't include any double-quotation marks in your CSV file, i.e. "
    In Windows 8, over and above what Clive suggested, on the same Regional Settings screen, change the decimal symbol from a comma to a full stop and repeat the two edits in the Currency tab. Also make sure that your system is set to English South Africa.
    Attached Files Attached Files
  9. #6
    Sep 2013
    Durban
    Brilliant.
    Thanks so much for all you input.
  10. #7
    Mar 2014
    Kampala
    whats wrong with the csv file i have attached? Im getting "date must be in the format DD/MM/YYYY" error msg.
  11. #8
    A shot in the dark here, but I've had a little experience with date fields mucking around for the strangest reasons -
    Check the short date format in your Regional Settings is set to dd/MM/yyyy
    (Assuming Windows 7 - Start > Control Panel > Region and Language )
  12. #9
    Mar 2014
    Kampala
    Importing a CSV file into Pastel
    Sure i checked that and my date format is dd/MM/yyyy. I dont see where im going wrong.
  13. #10
    Morningside, Durban
    I've had a look at your CSV file and the problem is that you have a blank row in between the rows with data.
    If you delete the blank rows, it should import fine.
  14. Thanks given for this post:
    Dave A (08-Mar-14)
  1. Pastel General Ledger importing
    By osbert in forum Accounting Forum
    Last Post: 10-Dec-15, 10:23 PM
  2. [Article] Pastel Accounting Tip: Journal Contras
    By Neville Bailey in forum Accounting Forum
    Last Post: 19-Aug-15, 01:55 PM
  3. [Question] Inventory journal entry on Pastel
    By Jackievdw in forum Accounting Forum
    Last Post: 19-Jul-13, 09:07 AM
  4. Debtors Ledger and General Ledger
    By Simimano in forum Accounting Forum
    Last Post: 15-Apr-13, 03:24 PM
  5. Create General Ledger accounts for take-on balances
    By Elize7 in forum Accounting Forum
    Last Post: 23-Jun-12, 09:26 AM
