Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Greener refrigeration system issues explained.
  1. #11
    CO2 is being heavily pushed for widespread use by governments. Large subsidies are available overseas to help offset the heinous costs involved for companies who make a commitment to use it.
    Green politics.
    Got to get those carbon credits somehow
  2. #12
    Platinum Member desA's Avatar
    South East Asia
    Yep, CO2 is not combustible, it's just the gas escaping when pipework ruptures. The pressures are immense, over 100Bar (1500 psi) and there's quite an explosion when a rupture occurs.
    There is also generally, compressor oil being transported around the refrigerant circuit. This oil can catch fire of an occasion with some systems. Not sure how much of an issue this may be with CO2, but at up to 150bar in some applications, the results could be interesting.
  3. #13
    Quote Originally Posted by desA View Post
    I'm not a refrigeration engineer but I've spent the last three months doing lots of homework.
    Oil catching fire might be a problem if a larger propane system had a big leak. Oil leaks from other refrigeration systems can be very acidic which is another problem. CO2 systems tend to run in a flooded state so liquid co2 could escape in the case of a large leak or pipework failure. CO2 much prefers to be a gas (or even a solid) a room temperature and pressure so the liquid would violently boil freezing anything it came into contact with. Cold burns to a person are just as bad and possibly life threatening as heat burns.
  1. PESTBIZ 2010 - GREENER, SAFER PEST CONTROL
    By Affinity in forum Pest Control Industry Forum
    Last Post: 26-Aug-10, 08:33 PM
  2. Economic models explained using cows
    Last Post: 09-Nov-09, 02:37 PM
  3. New demerit system-New driving points system hits the road
    By Candy Bouwer in forum General Business Forum
    Last Post: 23-Jul-09, 06:51 PM
  4. BEE explained
    By Marq in forum South African Politics Forum
    Last Post: 02-Apr-09, 09:17 AM
  5. Is the grass Greener off-shore ?
    By daveob in forum Tax Forum
    Last Post: 22-Jun-08, 02:01 PM
