I started a new thread for this topic because this is where things get a little more interesting.
Installing these inverters and setting them up is as simple as 1+2=3. As pointed out, 99 % of issue with these inverters are installer related, which is why technical support is so critical.
The system mode is the long division sum of the installation, once you understand how it works it will fall into place.
This section and the use of smart swtiches could be the diffenrence between a 10 year ROI and a 15 year ROI
I am almost at that point where all the installations I have completed so far are now ready to start tweaking.
What would the ideal setup look like:
1/ The cost to recharge batteries is limited to solar power, but will use the grid power as a last resort.
2/ Sunny days producing max power to run appliances which are linked to smart switches, and staggered to operate at different times, the balance of power will be used to make sure the batteries are at 100 % in the evening.
3/ Once everything is done and the batteries are full, the excess power will feed back into the grid. There is a small feedback credit offered(no cahs back), ours is R135 per kwh.
4/ In the evening the batteries will keep the essential power on, and so the cycle will begin in the morning.
5/ Depending on the amount of battery support, if ther eis excess power you could use it ot suppliment the peak demands.
How the system mode works, it allows you to opitmise the power from the solar and battery to assit with the load for the grid and top up the battery.
What are the key features:
* Battery percentage<br><br>* When the battery will charge and when will it discharge.
* Where the solar power will be distributed, priority to load, to the battery or export.
Why would you even bother ticking the "use timer" feature, to distribute the power during the day when you are generating power and to save money on your utility bill.
Once you start playing with the settings you can see how the power moves from the panels to the grid.
If you want to get the most out of your system , I would focus on this section and make sure you understand how it works.
Sunsynk are apparently doing tests on the smart switches, hopefully they will be avaiable by the beginning of May 2023.
I will try update and add expamples of setups we use as we live and learn.
Feel free to add any tips you might have with regards to system mode. I dont think people understand how this works and therfore not taking advantage of the savings
Most inverters systems are installed as backup systems for load shedding, but why not take advantage and get the most out of your system.
Remote viewing just makes fine tuning your system a whole lot easier.
