Class 1 - lightning protection
Calls 11 - Surge protection
Something I dont believe many people understand when doing a test report where there are PV panels on the roof and surge protection in the DB.
You need to understand the difference between lightning protection and surge protection, before you start scribbling and ticking the test report.
Once again feel free to add your comments about this topic, I am not lightning protection specialist and find it rather difficult to find people who know what they are talking about.
The panels on the roof you need to ask yourself the question, do I need to earth the panels and rails and by earthing them will lightning protection be required.
Note!!
"Whenever a building has external lightning protection such as a mast, or conductors on the building, Class 1 lightning current arresters are required."
Once you install a set of PV panels on the roof and link them together with an earth wire and take it to ground, then things get more interesting.
Do you install class I or class II surge protection in the combiner box?
If you use steel cable tray or steel piping between the panels and the combiner box do you run a bare copper wire and install an earth spike?
Do you connect this wire to the grid earthing system, knowing if there any transient spikes, there is a good chance your system is going to the lala land.
Do the PV green card training course go into detail about all this important stuff?
