Feedback or max continuous pass through current as it is referred to for a 5 KVA unit is 35 amps. It would be advisable to use a min. of 6 mm wire.
As per the spec sheet, an 8000watt unit standard output current is around 35 amp and the max pass through current is 50 amp, best you dont install anything less than 10 mm.
