Solar, inverter and batteries, why
    Why are you considering installing a system?
    1/ because you want to go off grid?
    Let’s have a look at the first option - Off grid.
    From the little knowledge and experience I have gained in the past 5 years of working with these systems, it is literally impossible to go off grid, unless you live in a small room with no appliances, are prepared to spend a lot of money on a large inverter, lots of batteries and a roof full of panels.
    The other option is to back up the systems using a generator; this has become a common practice.
    2/ You want an uninterrupted power supply?
    The second option has become a necessity in SA due to load shedding and the general lack of stable power. Some people just install an inverter and a battery, which will work if designed and setup correctly. Just be aware that if you are using FLA/gel or AGM, the battery setting and cut-out voltage is critical, get this wrong and your batteries will not survive a year. Temperature is a batteries worse enemy.
    Something else you need to understand, unless you are on a time of use tariff and you setup your inverter to charge the batteries at specific times (off peak) and use the energy stored during Peak times, you will NOT save any money. I cannot understand why people are telling customer they will save money when they install an inverter and battery. I have even seen installations with solar panels, which are so badly designed that the customers lose money even with panels on the roof.
    Something you need to understand, you have to charge the battery, If you decide to go with the cheaper option FLA, then the battery is gonna take a long time to charge and use a lot of electricity. The lithium will be faster depending on the battery charge rate, but still have to put the power back into the battery. While on this topic, for load shedding lithium is a better because of the charge rate. During stage 4 load shedding you want the battery to charge as fast as possible, so the C rating of the battery could become an important factor.
    3/ You want to save money?
    This is the difficult part, the only way to save money is to find a way to charge the battery that doesn’t cost and arm and a leg, you may think solar panels. You need to take into account the cost to buy, install and KWH production. If your electricity account is R1000 per month it will take forever to recover, then by the time you pay off the system, it might need to be replaced. Or newer better cheaper options will be available. Then there could also be tax rebates etc., which is apparently is being discussed in certain provinces.
    Once again design and setup, get this wrong and you back to wasting money. Understanding the time of use is just as important as understanding the load requirements. Setup to optimise the sun hours is the key to a good long term solution. What you do with the power being produced by the sun is how you will determine the savings or losses.
    It will require commitment from the entire household, shuffling the time tasks are carried out, Like the washing machine, don’t do washing at 7 am, or have your geyser timer set for 7pm to 9 pm and 3 am to 5 am. Don’t run your pool from 10 pm till 2 am. I am sure you already know this.
    Someone mentioned a booster pump for their water system, if your system is designed correctly, and your gutters are catching all the water and you need to move the water to the low level tank to the tank at the top of the property, make sure you understand your load profile and program your control system to operate certain item at the correct time.
    I am going to say this again, one size doesn’t suit everyone. You will only be able to optimize the system once it is installed and you have a way to view the charts and trends.
    • 1753
    I cannot understand why people put in expensive solar, inverter systems when there's not a rainwater harvesting tank in sight.
    It's cheaper to put in a decent rainwater harvesting system than a decent backup power system and also more important. One can survive without power ( my in laws did for 65 years ), but not without water. They lived at the foot of a mountain with a constant stream.
    In a house, installing solar has nothing to do with saving money. Period. It has to do with convenience. Convenience costs money.
    In a factory enviroment it is different.
    Ford in Silverton have installed a system which has a payback time of 5 years and presently are saving big bucks on electricity.
    The only way for a domestic installation to save on the electricity bill is to use less.
      If you live in a small one bedroom apartment, installing a roof full of solar will definitely not going to save you money.
        This is what I tell my customers, and I promptly lose the order to someone who talks nonsense and tells the customer what he wants to hear, installs some unsuitable system and rides into the sunset smiling, while I sit and wonder where all the business is going.
        Hmmm need to change the way I work if I want to survive.
        I am currently going through a rethink as the business of supplying top quality product and service under the current trading conditions is not producing the sales required to sustain the business.
          • 1753
          I have lost many orders for solar installs after telling the prospective client the truth, however, on numerous occasions, after the client has had a day or two to think of what I said, I get a call and end up installing a rainwater harvesting system for same client. Many happy customers.
          These 2 or 3 clients are more important to me. I get work for which I am grateful and inside, I know, I have been truthful and that I have influenced them into making the right decision as far as their priorities for survival are concerned.
          Have a lekker day.
            Have a lekker day.
            True, however what I am finding is that the customers who do return are are far and in between, that the profit made on the sale does not cover the business running expenses.
            At the end of the day, I also need to make a living, and if the current format does not make it, that's when one starts revising the way that you do business.
            I still maintain my integrity in my equipment and service level, but omit some information and provide it only if asked.
            Just had an experience a couple of days ago.
            My Customer - "Your price is expensive, and I have to compete with Chinese imports. The sale price tag of your product is R 5700.00 VAT inclusive, where the Chinese one is R 2230.00 VAT inclusive"
            Me - "You are aware that we are not comparing apples with apples"
            My Customer - "Yes I know, but the customer does not understand and looks at price alone"
            Me - "OK let me look at the Chinese product and make a comparative bid"
            A day later after racking my brains, throwing out all the bells and whistles, removing any piece of equipment which will make the installers life easier, and finding another enclosure which is IP43 as opposed to IP65, redesigning the electronics, I come up with a comparable price"
            My Customer - " Heck why did you not offer this to me before"
            Me - "Well you never asked, and just to remind you, the original product evolved to what it is today, because of all the issues and failures that we experienced in the last 40 years, and was requests made by you"
            So we are now going back to the beginning when we started in the early 80's. That knowledge and experience gained over the last 40 years is now erased, because of 'the price" is expensive.
            So here we start again from the beginning.
            Happy travels
            • HGTesla
              • Jul 2023
              • 7
              Renewable Energy Generation: Solar panels harness energy from the sun, providing a clean and renewable source of electricity. Many individuals and businesses install solar systems to reduce their dependence on fossil fuels and decrease their carbon footprint.
              Cost Savings: By generating their own electricity through solar power, users can reduce their reliance on electricity from the grid. This can lead to significant savings on utility bills, especially in areas with high electricity rates or when government incentives and tax credits are available.
              Energy Independence: Solar systems enable users to become more self-sufficient in terms of energy. They are less susceptible to power outages or fluctuations in energy prices, providing a sense of security and stability.
              Environmental Impact: Using solar energy instead of fossil fuels helps mitigate greenhouse gas emissions and reduces environmental pollution, contributing to a cleaner and healthier planet.
              Remote Power Supply: Solar, inverter, and battery systems can be especially beneficial in remote areas where access to the grid might be limited or expensive. These systems can provide a reliable power supply, improving the quality of life in such areas.
              Energy Storage and Backup: Batteries paired with solar systems allow users to store excess energy generated during sunny periods and use it during cloudy days or at night. It also provides backup power during grid outages, enhancing energy reliability.
              Supporting Technological Advancements: The adoption of solar and energy storage technologies helps drive innovation and advancements in renewable energy and battery technologies, leading to a more sustainable future.
