Results 1 to 8 of 8
Thread: Charging battery with solar charger and inverter charger
    Aug 2018
    Capetown
    Hi guys. I'm installing a inverter which charge the battery from the grid but want to connect a solar panel through a solar charge controller to that same battery. Will this work or am I missing something?
    Sent from my R1PLUS_1 using Tapatalk
    Jun 2020
    Fourways
    Also been thinking of this for my setup for when things get long...
    So my inverter i can switch off the charge and then I would put in the PV charger.
    May do a change over system for DC with contactors or manually do it.
    Now there is parallel charging where if you have the grid and the PV both joined and charging but I do not know enough on that especially if there is a BMS for lithium.
    So the parallel charging may be a good one.
    Not 100% planned it through yet as my new issue is i need water backup as we are out almost every 3 weeks.
    Feb 2022
    Yes you can charge batteries using both mediums or can charge simultaneously. It depends on batteries capacity and their condition of charge. In this case solar will work and supply current only if batteries are emptied and need more current otherwise, if inverter is supplying sufficient current then PV will not be generated.
    Jun 2020
    Fourways
    That is intresting ! Makes sense that if the inverter is doing its job and charging let's say 30A that the charge controller for PV will not have a laod as such and not work as such.
    Mar 2022
    Get yourself one of those pools with the metal frame, you get to swim in summer and have a backup water supply, the best part it doesn't fill up with mud when there are floods We had no water or electricity for 2 weeks, no problem. We normally just use buckets, but the way the infrastructure in this country is deteriorating, I plan to pipe the pool into the mains water. The other reason is the sewage is calculated on the water useage, so the plan is to pipe the toilets and washing machine, geyser directly to via the pool, it an all-round win. My gutter from my workshop and office is right next to the pool and we are at the bottom of the hill, so we have a constant flow of water through out property.
    Jun 2020
    Fourways
    Ahhh that's clever and a win !
    We have a jacuzzi with this rental place that I have some water in but not very user friendly hahaha.
    But I want to do the plumbing in bit as you say. Also needs to be removable as we don't own the spot and with the small one getting big we will be looking to move anyway.
    Hopefully then to also incorporate rain water collection to!
    Mar 2022
    The issue I see with rain water collection, the standing water becomes a problem, that's why I haven't installed JoJo tanks. The pool is open so when is starts looking bad, you just throw a shock treatment and walla the next day its clear again.
    Jun 2020
    Fourways
    Yes agreed on the water being stagnant. Pondered to then bave it permanently feeding the house with a booster pump so that water is always flowing in and out.
    Is that bad peactice for motor wear or an ok option ?
    Sent from my SM-P605 using Tapatalk
  1. Inverter battery selection
    Last Post: 12-Feb-21, 07:03 AM
  2. inverter battery charging
    Last Post: 16-Feb-20, 08:46 PM
  3. [Question] Inverter battery packs
    Last Post: 04-Nov-19, 07:30 AM
  4. [Question] when does an inverter battery charger cabinet become a hazardous location
    Last Post: 25-Jun-19, 07:15 AM
  5. [Question] Good Car Cellphone Charger and Holder?
    By AmithS in forum Technology Forum
    Last Post: 29-Dec-16, 08:17 AM
