Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Earth leakage tripping with no load ?
  1. #21
    Mar 2019
    East london
    Earth and neutral bridged in the prepaid meter which is usually in close proximity to the DB. Whole of East London. We have an ideal situation.
    Peace out ... Derek.
  2. #22
    planet earth
    So you use a TN-C-S system earthing ?
    We use a TN-C system earthing.
  3. #23
    planet earth
    " Only some of the suburbs, especially the older one's, where the service cables are overhead, no earth is supplied. Only 2 wires. Live and neutral.
    My house, for instance, is in one of these older areas but being a newish house compared to the rest, has an underground service cable where a seperate earth is supplied.
    My test video will be uploaded this coming weekend.
    Peace out ... Derek"
    I need to read all the posts
  4. #24
    Mar 2019
    East london
    Even where a seperate earth is supplied, it is still bridged with the neutral in the prepaid meter. Mine included.
    Supply Authority will NOT install the prepaid meter if that special copper link that is supplied with the meter bases is not in place between the earth and neutral on the meter base.
    You will notice that even although there is an incoming earth, if you look closely you will see a bare copper bridge between the earth and neutral.
    That's how it's done here.
  5. #25
    planet earth
    Your loop impedance test results must be low?
    I have been thinking ... this might not be a bad idea considering the rate at which earth wires are being removed from the overhead lines around here ... creating a huge problem with loop impedance tests.
  6. #26
    planet earth
    You should fit a main switch and a few cicuit breakers in your DB
  7. #27
    Mar 2019
    East london
    Ian, my brother. Anything above 0,5 Ohms and we know there's something not right. I mean we only checking the earth loop impedance up to the meter.
    Fortunately we have a good relationship with the guys at Revenue in the Municipality.
    Take a photo of the sealed meter, make a call and request permission to break seals and pull the meter in order to carry out inspection on base.
    Inspection done, one call and a technician from Revenue is there within the hour to re seal.
    My brother, that is one department that's on the ball here in our valley.
    Peace out .. Derek.
  1. Earth Leakage Breaker (RCD) Tripping
    By AndyD in forum Electrical Contracting Industry Forum
    Last Post: 14-Jul-23, 02:53 PM
  2. Ceiling fan tripping earth leakage.
    Last Post: 04-Feb-21, 09:04 AM
  3. Low earth leakage tripping current
    By SeanM in forum Electrical Contracting Industry Forum
    Last Post: 15-Mar-19, 07:19 PM
  4. earth leakage tripping issue
    Last Post: 16-Jan-19, 12:13 PM
  5. earth leakage tripping
    Last Post: 23-Jun-15, 11:27 AM
