Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Section 7.12 Alternate supplies
  1. #11
    Nov 2019
    Alberton
    7.12.2.1 - Notices and audible or visible power on indicators.
    I did not install visible power on indicators because my prepaid meter is right next to my DB with a light display when “Eskom is on” it is light up and also an inverter keypad right next to the prepaid with a light display when inverter is on. I did not see the need to install more lights due to these visible displays but am wondering if the displays could be regarded as visible indicators. I did then label the DB to warn of “Alternate solar supply “ any advise on my scenario?
  2. #12
    Nov 2019
    Alberton
    Alternate supplies are growing fast and this industry requires urgent attention.
    I have came across installers doing complete solar installations with very little knoledge of the SANS wiring code. They then get an installation electrician to come and install just the change over switch. The electrician than issue a C.O.C. for that C/O switch and the installer switch on the solar as if all is compliant. This to me is a gray area as to what regulations were followed doing the dc wiring, circuits and fuse ratings on batteries and pv panels.
  3. #13
    planet earth
    Quote Originally Posted by Rifrug View Post
    There is an even better way to do it ... you do the full installation ...install an electric fence ... fit a gas oven a ... do all those alterations around the house ... then tell everyone you are putting the house up for sale ... contact a company which specialises in COC's ... get them to do a full inspection report and COC for the entire installation
  4. #14
    planet earth
    As per image on pg 359 of the sans book ... do you install physical barriers between the normal and eseential supply or do you just leave a gap between the breakers?
    or do you install a 2 level DB one for normal and one for essential?
  5. #15
    Nov 2019
    Alberton
    To my understanding there should be a physical barrier between the different supplies, It would be even better if they could be in different DB’s but the aesthetics become a factor when the DB is inside a main living room or undesired area, who appreciates clusters of DB’s in a home. Also to install a separate DB for four little switches become uneconomical so my preference in a home would be towards installing a physical barrier between supplies if it has adequate space, and ensure that it is clearly labelled with warning signs.
  6. #16
    Nov 2019
    Alberton
    I also prefer one DB with the Eskom Main Switch section and also the Alternate power main Switch section so that both switches can be easily switched off without going through a building looking for where the alternate power main switch is situated.
  7. #17
    planet earth
    This barrier issue was bought up in a dispute between a solar installer and the customer local electrician.
    The question is do you fit a piece of poly carb from the top to the bottom ... or would you regard 2 clipin blanks as an adequate barrier.
    Personally i would think a circuit breaker space/gap between the eskom and alternate power would be adequate.
  8. #18
    New Member montronic's Avatar
    Mar 2013
    PMB
    What if I want to install a isolated low voltage dc system (24V or 48V) in my house? Are there any regulations for this?
  1. alternate supplies
    Last Post: 31-Jul-20, 12:29 PM
  2. Multiple supplies in one building
    Last Post: 24-Jul-19, 11:50 AM
  3. COC For Alternate Supply
    By MullerR in forum Electrical Contracting Industry Forum
    Last Post: 27-May-16, 09:07 AM
  4. KA testing on UPS Supplies
    Last Post: 22-Jul-14, 06:33 AM
  5. Fuel supplies fragile
    Last Post: 27-Apr-08, 01:54 PM
