Results 1 to 8 of 8
Thread: Over voltage and lost neutral protection
    planet earth
    Anyone tried these units... i see they have an interesting range of protection devices.
    https://za.rs-online.com/web/p/surge...units/3115925/
    Dec 2013
    Western Cape
    Sounds like a very sophisticated power surge arrestor and expensive
    Mar 2019
    East london
    Hi Ian
    Price a bit steep, but looks good. Haven't used this unit.
    I have however used the Fridge Safe unit from Ellies rated at 5A together with a single pole contactor for more oomph.
    This combination 25A works out at about R1200.
    Cheers & peace out .... Derek.
    I have a product which is similar and way cheaper.
    3P5WVSPC-005 - 3 Phase 5 Wire Voltage and Surge Protection Control
    Easy to install
    All 3 phases Voltage Monitoring
    Phase sequence protection
    Earth Voltage monitoring
    Nuisance free Delay before trip
    LED Indication of Status
    Power on delay
    Delay after each fault
    Time Save Delay on each Fault
    Surge protection on all phases
    Surge protection between Neutral & Earth
    LED indication of Surge Arresters operational
    Designed for extra-long service life
    See my brochure
    3P5W Surge Protection.pdf
    Hi Ian
    Interesting some 10 years back a made a product which I sell into Mozambique and locally called a Fridge Guard, which works well. Have had it on my fridges and to date with all the power issues have not had a fridge failure. This included a holiday home in Limpopo which had major voltage issues.
    The Fridge Guard comes in two low cost models for home , office or factory use. Namely a 16 Amp resistive (8 Amp inductive) and a 30 Amp resistive (20 Amp inductive load) versions.
    Typical applications include, refrigerators, electric motors, electric mixers, sensitive control equipment, lighting equipment, etc.
    3 coloured light emitting diodes provide positive feedback to the user, showing the status of the mains supply at all times.
    Red - Over Volt, supply over 265Volts
    Green- Under Volt, supply less than 186Volts
    Flash Yellow - Wait to start, voltage within 186 and 265Volts
    Yellow - Volt O.K., load connected to mains and voltage between 186 and 265Volts.
    5 minute delay after voltage recovery or power up delay.
    ABB also do a din rail clip in voltage monitoring relay at 22,5mm wide at around 3K - You need to fit a contactor to match the load
    My unit for a similar price includes surge protection
    planet earth
    I have a customer who only wants ABB products installed... What separates ABB from the rest is their circuit breakers have a dual terminal ...so you dont have to squeeze 2 wires in one terminal...you pay more but at least you get what you pay for.
  1. Lightning protection vs surge protection
    Last Post: 28-Feb-20, 08:02 AM
  2. Voltage between Neutral and Earth - When is it a fault?
    By Justloadit in forum Electrical Contracting Industry Forum
    Last Post: 20-Jul-19, 09:23 PM
  3. ELEVATED VOLTAGE TO NEUTRAL ABOVE 50 V -NOTICE OF POTENTIAL DANGER
    By Tshepo Mokoena in forum Electrical Contracting Industry Forum
    Last Post: 26-Apr-18, 08:26 AM
  4. Elevated voltage on supply neutral measurement
    By PaulG in forum Electrical Contracting Industry Forum
    Last Post: 05-Mar-16, 07:45 PM
  5. Difference between: Power factor correction, Voltage regulation and Voltage stabisizi
    By BigRed in forum Electrical Contracting Industry Forum
    Last Post: 08-Feb-10, 09:29 PM
