Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Ceiling fan tripping earth leakage.
  1. #11
    planet earth
    Hi All
    A bit of feedback.
    Meggered the motor. Result infinity.
    Connected the fan in my workshop and tested.
    Turned it on and off a couple of times ..... no problem.
    Left it running for an hour. When I turned it off, the earth leakage tripped.
    While the motor was still warm, I meggered it again and found the reading to be lower than when the motor was cold. 1,5 megs.
    The insulation resistance is reducing with an increase in temperature.
    I am aware that the earth leakage should only start tripping when the insulation resistance is approx 8k or lower, but I suppose the reduction in insulation resistance combined with the arc from the switch does something that causes enough current to earth to trip the earth leakage.
    I still don't fully understand the theory behind it, but I now know that it's the fan that's faulty.
    Derek
    Until you actually find the fault... you will never know....how does the saying go... clutching at straws.
    something to consider...the motor turns...its hanging on a shaft... wiring gets warm (even if it doesnt get warm)...as the motor stops...the wiring shorts on the frame ...e/l trips...i would bet money on the neutral being the cause of problem.
    The wires are always squashed through the tubes and out through a hole into a connector block... do you have a leakage current clamp?
    if not...hang the fan ...connect the insulation resistance tester set to 1000 volts ...shake the bottom of the fan and see if the reading drops while doing this.
  2. #12
    Oct 2011
    port edward
    Hi All
    A bit of feedback.
    Derek
    This is why i always said , "electricity is a mix of science and magic"
  3. #13
    Feb 2021
    Vadodara
    Hello, There
    Ceiling fan tripping earth leakage may be it is happen due to the poor wiring or also due to the earthing problem in house. One of the simplest grounding problems to fix is making sure that all ground connections are correct.
  1. Earth Leakage Breaker (RCD) Tripping
    By AndyD in forum Electrical Contracting Industry Forum
    Last Post: 14-Jul-23, 02:53 PM
  2. Low earth leakage tripping current
    By SeanM in forum Electrical Contracting Industry Forum
    Last Post: 15-Mar-19, 07:19 PM
  3. earth leakage tripping issue
    Last Post: 16-Jan-19, 12:13 PM
  4. Earth leakage tripping when plug in snake rack
    By MattyN in forum Electrical Contracting Industry Forum
    Last Post: 22-Aug-15, 09:29 AM
  5. earth leakage tripping
    Last Post: 23-Jun-15, 11:27 AM
