At the moment you do not need an engineer to sign off on Solar installations , unless you get to the really big ones that are being dealt with under REIPPP programs .
At the moment the biggest you can go is 1MV privately and I stand corrected.
In my opinion the Solar industry has been hijack to some extent by those that see it as a quick buck.
Some are also quick to say that they regulations, SANS 10142-1 do not cover DC/PV even though the Introduction in the book clearly states that it does (pasted in Red below) .
There is also misconception that the circuits between panels are control circuits when they are in fact power circuits.
An Electrical contractor cannot sign off on a job unless he was in general control.
The whole solar regulation is being looked at again and it has not been decided yet if it will continue forming part of SANS 10142-1 or if a different set of regulations, SANS 10142-3 may be created.
To me the biggest problem is that the majority of people are not taking into account the various bylaws ( Fire , Structural , Municipal ) when installing and future maintenance.
Introduction
In this edition an attempt has been made to move towards the IEC codes:
extra low voltage (below 50 V) and d.c. applications (up to 1,5 kV) have been
introduced as new requirements owing to the extensive usage of, and
increased fire risk that result from, high load currents. This part of
SANS 10142 does not intend to cover the LV control circuits of machinery or
system components that are external circuits between separately installed
parts of the machinery or system components.
This part of SANS 10142 includes certain provisions which are for
information and guidance only. These provisions do not use the word "shall"
and they can be found in the text, in the notes and in the informative
annexes. Except in tables, notes are always for information only.
The aim of this part of SANS 10142 is to ensure that people, animals and
property are protected from hazards that can arise from the operation of an
electrical installation under both normal and fault conditions. An electrical
installation has to provide protection against
Introduction
