Results 1 to 4 of 4
Thread: Gas Stove Consumption : Oven
    May 2014
    Lightbulb Gas Stove Consumption : Oven
    Hi all,
    I've got a gas stove, I use it a lot during the week. I usually get a 9kg bottle. Now I need to work out how much gas the oven, not top burners, uses on highest setting per hour. I have no clue how to calculate.
    Bottle:
    LPG Gas 9kg @ R380 per bottle
    Stove info on the label:
    Gas Supply 2.8Kpa
    Design consumption: 415g/h
    Loading Heat 13800w
    Heat Load: Burner 0.88mm and 2700w (on the oven section of the sticker back of stove)
    Please come to my rescue.
    Full Member smithers's Avatar
    Sep 2012
    cape town
    Oct 2008
    Not sure how these calcs work.
    Wouldn't it be 9kg divide by Design consumption: 415g/h = 21.69 hours of usage
    Trying to calculate the gas consumption from the heat output stated on the oven is going to be hit and miss. The oven will have a modulated gas valve which is fully open when the oven temperature is below the set temperature but it will close when the oven gets hot enough so the consumption is not a constant. Best way would be to physically weigh the gas bottle before and after you use the oven for an hour or two.
  1. Domestic Fridge Energy Consumption.
    By AndyD in forum Electrical Contracting Industry Forum
    Last Post: 27-Jan-16, 09:26 PM
  2. gas hob/electric oven
    Last Post: 25-Sep-15, 02:33 PM
  3. Oven Element Replacement
    By rfnel in forum Electrical Contracting Industry Forum
    Last Post: 29-Jun-11, 11:08 AM
  4. Take our snap electricity consumption survey.
    By Dave A in forum News Archive
    Last Post: 18-Feb-08, 08:51 AM
Tags for this Thread
