Results 1 to 10 of 10
Thread: COC and Brass Heritage switch
    Had a phone call this morning in connection with a COC inspection being done in an old house , all refurbished with oregan pine wooden doors , floors etc.
    Need to ask all the clever people what you would do if you came across the old type Heritage brass switches ( similar to pic ) in an installation The switches fit in beautifully with the finishes and anything else will ruin the finished look.
    The outer brass cover screws onto the brass toggle - The switches are mounted on the wooden door frame
    My feeling is that the switches need to be replaced with something as it is not possible to earth.
    I know Clipsal used to do the heritage range which made life simple , but it has been discontinued
    Interested to know what you would do
    Name:  Heritage  switch.jpg
    Jul 2008
    Germiston, South Africa
    The same thing happened to me when I did a COC in Johannesburg about 12 to 13 years ago.
    I called my contact at the ECA and was given the following advice.
    There is a space between where the wires are connected and the outer metal Parts Of The Switch. There was also a piece of porcelain distancing the actual switch rocker from the workings of the actual switch.
    I was advised to pass it as being reasonably safe which I did.
    Jul 2008
    Also see SANS 6.12.3.2
    Neither of the cover nor the toggle switch are touching a conductive surface and meet requirements in parts C4
    HI
    Also looked at 6.12.3.2 -(2) - need not be earth if ,2) out of arms reach from a structure that is bonded to earth
    Then read a bit further to 6.12.3.3 - Metallic frames and enclosures of electrical equipment shall be made electrically continuous
    Decide to check on definition of electrical equipment - item or combination of items , including wireways, which is used for generation , conversion, transmission or distribution of electrical energy.
    Seems that 6.12.3.3 is in direct contradiction to 6.12.3.2
    Wonder why I became a Sparky when I actually need to be an English professor, or Lawyer to try and understand what we can and can't do.
    Can the toggle and cover no9t be classed as an extraneous conductive component if the IR to the MET is >7.6kΩ? I'd be tempted to hold it to a far higher standard of IR though if there's any other conductive items within reach that weren't extraneous.
    Jul 2008
    It seems there is a mistake in the SANS
    6.12.3.2 has two part C,s and one part A
    However.....
    6.12.3.2 The following do not need to be earthed:
    b) Exposed conductive parts of fixed electrical equipment that are
    4) not touching a conductive surface.( The bell cover is usually screwed onto a bakerlite base)
    6.12.3.3 deals with metallic frames and metallic enclosures
    6.12.3.3 Metalic frames and metallic enclosures of electrical equipment shall be made electrically continuous
    The bell cover is not a frame.
    The bell cover is part of the electrical equipment as a whole. An enclosure is a part that protects the electrical equipment from exposure such as a metal box or a DB
    Just my two cents worth
    AndyD (25-Apr-18)
  8. #7
    And no part b.
    Quite clearly a typo and needs to be passed onto the technical committee, I suggest.
    Good spot, Leecatt
    Question - When you remove that metallic cover, doesn't this expose conductive / current carrying parts?
  9. #8
    Jul 2008
    And no part b.
    Good spot, Leecatt
    Yes, the conductive parts would be exposed, which would put it in contravention of SANS 5.2.1 b)
    Perhaps a strategically placed screw?
    GCE (26-Apr-18)
  11. #9
    Hi Leecatt
    Thanks , I think you are spot on and that under 5.2.1 the old type heritage switches would need to be removed .
    Somebody will come back with the date of installation and that therefore they were allowed to be used then - I would agree as long as no rewiring has happened.
    Most of those switches where installed in the day of VIR wiring so there would have been alterations to the installation.
    I was contacted yesterday and told that GLO electric have a new heritage type switch with an earth pin.I would rather replace all the switches and sleep at night
  12. #10
    Thought I would resurrect this conversation to see if anybody had a new view or idea
    We have just been asked the question again and I still seem to think that VIR and old brass switches should be replaced
  1. [Question] Help with hob plate/switch
    By Houses4Rent in forum Electrical Contracting Industry Forum
    Last Post: 08-Apr-17, 07:43 AM
  2. [Question] Changeover switch
    By Clive287 in forum Electrical Contracting Industry Forum
    Last Post: 03-Nov-16, 07:00 AM
  3. Hi all, i want to know something about heritage day.
    By shani in forum General Chat Forum
    Last Post: 20-Sep-11, 03:01 PM
  4. Main Switch?
    By Sparks in forum Electrical Contracting Industry Forum
    Last Post: 08-Feb-11, 10:16 AM
