I think he meant R15 a KG = 120/8 = 15
1KG of gas is equivalent to 1L of petrol.
I usually pay R190 for 9KG, much higher.
Maybe 'gasification' is the solution, where 1.5KG of wood will produce 1m^3 of gas which when compressed will weigh 1KG.
It is fairly easier to make the gasification tank and scrubber, just need some time and a workshop. There are a number of plans on the net showing how to make the system.
tec0 (06-Aug-15)
i made the correction accordingly, sorry bout that it is called "going without sleep for nearly 40 hours" The brain does get tired eventually. As far as i know certification is needed on gas but is worried about theft. There are reports of gas cylinders themselves are being targeted for theft. Not just where i live but many other areas. So was looking into using expanded metal mesh to maybe fabricate some kind of a cover that can be locked securely.
It will also stop people from tampering with it messing around with it. I don't know if this is allowed or not ?? Any ideas on that?
A galvanized adjustable plate metal bracket bolted to the wall with a locking device to prevent theft of the gas tank.
the bracket protrudes the correct distance and is hooked at the bottom to receive the lower rim and weight of the tank, is bolted with heavy duty rawl or similar bolts to the area behind the tank to prevent fiddling when the tank is mounted and a curved adjustable section at the top which drops into the top rim to firmly fix the cylinder in place, this has a locking device (Padlock or similar with protection shield)
Can be designed to adjust and accept 9 and 18 Kg or larger tanks as required, so if 18 is normal and only 9 is available no problem.
As far as I know gas containers HAVE to be kept in a ventilated lockable cage.
Chaps, be aware too that LPG prices are, like petrol, determined by the Department Of Energy and revised every month.
Sellers may charge less, but not more. Every winter the price is increased by some dealers, which is actually illegal.
The price at the moment was revised 5 August. I have attached the determination. You will need to look up the relevant Area Code on Dept Energy website. LPG-Regulations (2).pdf
Wrong, HR - they don't have to be in lockable cage.
The regulations for Gas installations are below: I recently had to research to ensure one on my Clients complied.
Gas.pdf
tec0 (06-Aug-15)
Ok .... I got a quote to install a gas geyser with two bottles outside - The guy told me it had to be in a cage. Looks like he was confused.
I think a gas water heater is a very reasonable option. I don't think gas heating is much cheaper (if any) than electrical heating but they have much lower losses because they're not constantly holding 200 litres of hot water which I think is where most of the savings are coming. This is offset against the inconvenience of having to keep a spare bottle and having to get refills every few months....but hey, you can't have everything I guess. I have a gas geyser in the workshop and offices to supply the bathrooms including 2 x showers, the workshops and the kitchen. Off hand I think the output is 22 litres per minute which with hindsight was maybe oversized, the showers are very hot and difficult to balance to a comfortable temperature with the cold water. The gas heater cost around R3500.00 last year which was cheaper than those useless steel geysers that last a year or two if you're lucky.
As promised did a refill yesterday here is the math
7kg gas cylinder cost me little over R153 to refill. It is of note that out of the 4 places doing refills only 1 had gas to sell.
Math 153/7 = 21,85714285714286
Rounded amount = 21,86
So that is R21,86 per 1Kg
A hell of a lot more then last time.
