Page 5 of 25 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 242
Thread: Saturday at home, installing an inverter
  1. #41
    Here a picture of it for those not too interested in reading the brochure
Name:	Power Meter.jpg
    bones (07-May-15)
  3. #42
    Quote Originally Posted by bergie View Post
    ...........i wouldnt recommend a 1kw at all. if you run these inverters full load all the time it wont last long.........
    This was one of the reasons I installed this unit in my home office, I wanted to put it under a test regime before I offered them as an option to customers. I've performed a series of marginal and substantial overload tests under varying ambient temperatures on it whilst monitoring internal component temperatures to see how it performed. I've run it under highly inductive and highly capacitive loads and I've also run some controlled short circuit tests to check disconnect times of OCPD's etc and fault current handling abilities of the output components and internal safety systems.
  4. #43
    Sep 2010
    cape town
    andy, is it the 1kw axpert inverter you are testing? for blacknights purposes it probably would be under rated
  5. #44
    It's the 3kW unit same as Blacknight was looking at for his installation.
  6. #45
    Email problem IMHO's Avatar
    Jan 2012
    NW
    Andy, need your help!
    As you know I run a guesthouse and I am looking at getting away slowly from Eskom. I am changing my geysers to gas as they pack-up. Done two so far, plenty to go. Stove is gas now as well. The next area I need to tackle is my laundry. I used the clamp tester method as you showed and here is the results. I would love to put the laundry on solar. I use the tumble dryers a lot, as it is the only way to get our towels soft. The washing machines also work hard. Ironing is 3 irons for about 2 hours a day, but lets work on 4 hours a day.
    Appliance Iron x 3
    H/day 4 hours
    Amps peak 7.8A
    Amps normal 0
    They switch on and off, so it is either peak or off, They switch on for a minute or two to get to temp and then switch on and of every few seconds, say 30sec intervals.
    Appliance Tumble Dryer1 (10kg)
    H/day 4 hours
    Amps peak 13A on switch on
    Amps normal settles to under 8A
    Peak at 13 amp very short. Then stays on 7.8A about for the duration.
    Appliance Tumble Dryer2 (5kg)
    H/day 2 hours but very seldom uses it. Just on very rare occasions.
    Amps peak A on switch on
    Amps normal settles to under A
    Peak at amp very short. Then stays on A about for the duration.
    Appliance Washing Machine Whirlpool
    H/day 4 hours (actual 3 but work on 4)
    Amps peak 5A on spin
    Amps normal settles to under 3A
    Appliance SpeedQueen
    Amps peak 8A on spin
    Amps normal settles to under 5A
    My aim would be to get these appliances completely off grid, with solar. So I need to know the inverter size and specs, batt capacity and solar panels to do the charging. Rainy or cloudy days, I will have to revert back to Eskom. Or will it be cost effective to have battery capacity to last 4 days? I would also need something to tell me what capacity is left. (Like a petrol gauge, hehe)
  7. #46
    Jan 2012
    NW
    Another thing to consider. Whasing is done in the mornings and ironing in the afternoon, with tumble drying between washing and Ironing.
    Lets say 8am to 10am washing
    11am - 1 pm tumble drying
    2pm-4pm Ironing.
    Above is a tipical day. As you can see, I overstated some durations above. I omitted tumble dryer 2's specs above, as I do not have it. It can be ignored.
  8. #47
    A couple of observations to start with, the washing machine current draws are lower than I would have expected for commercial machines, are they being supplied with pre-heated water? If they're heating their own water I think their maximum load should be higher durng the heating cycle than during the spin cycle.
    Secondly the tumble dryer with it's short peak of 13A,is this the motor start current or is the duration of this peak longer than a second or two?
    Also can you define the overlap between the washing and drying and ironing where two of the operations are taking place simultaneously or even all three operations?
  9. #48
    Jan 2012
    NW
    No, we wash cold water only. I only measured spin cycle, due to this reason. I can use hot water, but that is supplied via the hot water tap, from the geyser. I will test again when they use the machine again. BTW, it is not commercial machines, it is the normal household big Whirlpool and SpeedQueen machines, +-12kg
    Secondly the tumble dryer with it's short peak of 13A, is this the motor start current or is the duration of this peak longer than a second or two?
    No, a second or two. If you do not watch closely, you will miss it.
    I cross questioned the staff and my wife on this today. Seems like there is no overlapping. Washing is done early morning when they are still cleaning rooms. Then when the tumble drying start, it is to uncomfortable in the room to do ironing. I realize that saves me a lot. I will just have to make it law that there is to be no overlapping, even as an exception, and install an alarm type buzzer that warns when the threshold is reached or tripping out at a safe amp-age cutoff?
  10. #49
    Jan 2012
    NW
    The bulk of the laundry, namely the sheets, is send to someone else to wash and Iron. We do only a little bit of that, if we get our planning wrong. Our biggest loads is towels and pillow cases, plus clothing.
    PS. I have just been informed we do a fair amount of sheets ourselves now as well, as the laundry in town can not keep up. But we stick to the hours mentioned.
  11. #50
    Sep 2010
    cape town
    i think the top loaders should all have a separate hot water connection and the front loaders have a built in element,with no hot water connection. i speak under correction.
  1. [Question] Installing new electrical outlets in my home
  2. Was Saturday 11th's Important Announcement a bad PR exercise?
    By gac in forum South African Politics Forum
    Last Post: 13-Feb-12, 01:37 PM
  3. Installing Pastel express V.11 on Laptop.
    Last Post: 07-Dec-11, 02:52 PM
  4. Installing Windows XP on VB
    By Faan in forum Technology Forum
    Last Post: 17-Jun-11, 07:18 PM
