Did you complete both degrees?
Its one degree, I just tried to describe what it entails as Production Technology is generally not known. Especially not here as I did it in Germany.
I also did a CPIM from USA (Certified in Production & Inventory Mgt) i.e. Supply Chain Mgt
Houses4Rent
083-3115551
Cool.
Houses4Rent I would stick with a test lamp for voltage and a bell tester for continuity (you get a buzzer on most of the Digital Multimeters normally on diode test function) my favourite instrument is a line tester Duspol it gives led indication for A.C. and D.C. in range of Voltages from 6 to 500 and has a photocell powered continuity tester. Batteries dont go flat no ghost readings easy to handle no test leads breaking down straight forward indicates 230V or 400V in glowing red L.E.D.'s
