Good news I went to the customer and asked what they wanted me to do, and to my surprise they just said next time run it on thicker board. I was gobsmacked.
@Ian
Cool.
Here is a bright idea for you. I always found it very hard to see exactly what the laser is up to because the area around the nozzle is quite dark. I used to look at it using a torch.
This is my solution: I bought one of those cheap USB lights, stripped the USB plug off, fitted a bright led. I then clamped the fixture onto the laser head and wired the led into the main power supply. The thing is an absolute Godsend. I can clearly see what its up to now!
Adrian, terribly sorry to hear of your laser problem and resultant fire. Fortunately your staff are well trained, they knew exactly what to do in the case of an emergency..
Spelling mistakes and/or typographical errors I found in leading publications.Click here
sabbaticus
I've got the machine running again. I couldn't find a new belt anywhere so I ended up splicing two belts together. Half of the damaged belt and a spare short one. I replaced the air tube as well.
Although its a nasty incident it does bring many good lessons.
1. Always have a fire extinguisher at hand.
2. Never leave a machine to its own devices.
3. It forced me to clean up because all the junk lying around is a fire hazard.
4. Never block the laser's airflow.
I actually consider myself lucky because I was able to learn these lesson without too much serious damage, many people don't have that opportunity.
...and of course, $h1t just happens and the trick is just to learn from it.
