Health on regulation of melamine in foodstuffs
  • I Robot
    Administrator
    • 783
    Regulations published on maximum levels for Melamine in foodstuffs
    17 February 2009
    The regulations relating to maximum levels for melamine in foodstuffs have been published in the Government Gazette on 28 January 2009, by the Minister of Health in terms of the Foodstuffs, Cosmetics and Disinfectants Act, 1972 (Act 54 of 1972). The regulations have been published as a draft and interested parties are invited to submit substantiated comments or representations on the contents to the Director-General (DG) of the Department of Health (DoH), for attention: Directorate: Food Control by not later than 28 April 2009.
    The publication of the regulations is in response to the food safety incident that occurred during the second half of 2008 in China. The health of a large number of infants was affected by the consumption of dairy products manufactured from fresh milk intentionally contaminated with high levels of Melamine as a masking agent for the addition of water to the milk, by unscrupulous persons in China, which also resulted in a number of infant deaths.
    South Africa was not directly affected by the incident that occurred in that country, as indicated through the analysis of a number of samples of foodstuffs containing dairy as an ingredient originating from China, of which only a sample of white rabbit sweets tested slightly above acceptable levels for melamine.
    Through the monitoring and control measures applied by health authorities locally during that time, it was, however, discovered in November 2008 that some of the locally manufactured foodstuffs intended for infants and young children contained melamine slightly above the internationally accepted cut off levels. The cause of the contamination was established to be maize gluten originating from China used in the manufacturing of animal feed supplied to a small number of dairy farmers in a specific area in the country.
    Although not a significant threat to public health, the levels found was above the internationally accepted levels for the presence of melamine in the foodstuffs in question and steps were taken as a precautionary measure, by the manufacturer and the health authorities to ensure the removal of the specific batches of the products concerned from the market place in South Africa.
    Once finalised, the regulations will ensure that manufacturers and importers of foodstuffs in South Africa will have clarity on the legal limits set for the presence of Melamine in their products, It will also further strengthen the monitoring and control measures applied by the environmental health practitioners employed by the provinces for imported foodstuffs and by the metro and district municipalities for locally manufactured foodstuffs.
    The draft regulations stipulates that any foodstuff containing Melamine at a level above one milligram per kilogram for foodstuffs intended for children under 36 months of age and foodstuffs for special dietary uses, and 2,5 milligram per kilogram for all other foodstuffs, are deemed to be contaminated, impure or adulterated.
    Any melamine levels found in foodstuffs above these proposed legislated levels will constitute a criminal offence in terms of the Act if such foodstuffs are manufactured, sold or imported in South Africa. The mentioned levels are also in line with those set by a number of countries in their legislation, including Australia, Canada and the European Union (EU). It was further confirmed by the World Health Organisation (WHO) that the levels are adequate to ensure sufficient protection of the health of consumers, as confirmed by a meeting of experts convened by the WHO that took place in Canada in December 2008.
    Further information as well as a copy of the draft regulations can be obtained from the Directorate: Food Control. The draft regulations are also available on the webpage of the Directorate at: http://www.doh.gov.za/department/dir_foodcontr-f.html
    More...
    All it takes for evil to flourish is for good men to stand by and do nothing.
  • duncan drennan
    • Jun 2006
    • 2642
    I am not too sure who exactly will be held liable in the case of a criminal charge, but I an guessing the buck stops with the directors.
      • 22810
      With proper food safety systems in place, it becomes quite easy to establish who is responsible - once you cut through all the dust created by people diving for cover
      This melamine "contamination" business was absolutely criminal and I believe people are going to jail in China over the issue.
      • duncan drennan
        • Jun 2006
        • 2642
        Death sentences were given to two in China
          • 22810
          They should have been made to eat their own product for a year
          • Yvonne
            • 361
            How is it possible that ANY amount of melamine is "permitted"?
            Surely melamine cannot be present in any product - except intentionally?
            Yvonne
              • 22810
              Even if you have zero tolerance, you still need a reference point for testing purposes. Do you need to test for accuracy within 1% or 0.001% sort of thing.
              • Yvonne
                • 361
                Sorry, I understand what you are saying, but believe any measureable amount is to be deemed as contaiminated, impure or adulterated for ANY foodstuff intended for consumption.
                It should read - Any measurable quantity equal to or more than 0.01% of melamine must be deemed to be contaminated, impure or adulterated for any foodstuff either for special dietary uses or all foodstuffs.
                Less than one milligram per Kilogram is still unacceptable.
                Next we go the same route for "arsenic" if someone thinks it improves the quality or taste of foodstuff, where does legislation draw the line.
                Apologies for my reply, but surely, surely plain common sense, any harmful substance in any foodstuff - at any measurable percentage! should result in criminal charges.
                There is no question of "intent to do harm"!
                I like the suggestion that they must eat their own product for a year, how I would personally love a return to the ancient laws of punishment through wisdom, befitting the crime.
                Yvonne
                  • 22810
                  1 milligram per kilogram is 0,0001% or one part in a million by weight.
                  • Yvonne
                    • 361
                    Oops! Sorry,
                    I am not technically minded, (obviously), and was not interested in the actual % or calculation!
                    Reply was a knee jerk reaction, and I will attempt to avoid the temptation in the future!
                    Yvonne
                      • 22810
                      I'd guessed as much. Your sentiment is spot on, though. So good for you
                      BTW, one part in a million is about as intolerant as it gets when it comes to specs for contamination. Up until fairly recently extremely intolerant was considered at 10 parts per million, mainly because the ability to detect contamination at lower levels just didn't exist.
