Friday brain teaser:
Back in the days of energy savers and incandecent lamps, we knew the load had to be calcualted depending on the type of lamp, it would be calcualted as inductive or resistive loads.
Now we have LED fittings, they dont flicker to switch on indicating they are and inductive load, yet they are controlled by a electronics, they switch on instanntiously like a resitve load.
The question would be, how do you select relays for switching, do you use the industive rating of a relay or the resistive rating of the relay.
