Sunsynk for dummies
    #46
    Anyone moved a Sunsynk inverter from one site to another?
    I have a couple units on my workbench which I am busy preparing for site.
    Will the inverter connect to the router on site using the same method mentioned in the last post?
    My plan is to setup the unit save it to a file, then factory reset on site and upload the file.
    I am hoping the inverter will link to the site router without any challenges.
    I am also going to start making up complete systems ready to go.
      #47
      I see Ellies have woken and realised how big the demand is for Sunsynk in SA.
      It is going to be interesting to see if they can compete with the other distributers in SA.
        #48
        I am thinking this could have something to do with the mesh network (had a few challenges with a Pi3 operating solar assistant and a mesh network)
        I had it connected to the mesh network before, there is a full signal, so it must be something simple.
        The only thing that has changed, you could only see one SSID before, now we have 7 of the same SSID's when I scan, just at different levels of strength.
        I will try swopping routers around in my workshop and see what happens when I try reconnect.
          #49
          It looks like I am on the right track.
          I swopped the dongles on the units in the workshop, no problem.
          I switched off the router feeding the workshop to simulate the site issue. Went through the setup process and they all linked to the office router, no problem.
          Went back to site with spare dongles and routers.
          Step 1 - Setup the dongle on site to connect to my workshop router ( I had in the van), no problem, it links to my router and remote view works.
          Step 2 - Tried to connect to the site router again, no luck.
          Step 3 - was going to swop the dongles, however I didnt have to do this because it worked with the workshop router.
          So It looks like something in the site router settings is blocking the connection to the dongle.
          I need to find a smart IT fella who knows about router setting so we can figure out what is restricting the access.
          It is not a microtik router, I dont even waste my time when I see, them I just tell the customer their IT people to open links for the devices we need connected.
          At least I know it is not inverter or dongle related, now we can move a step closer to finding the solution.
          • Dylboy
            • Jun 2020
            • 777
            #50
            Uncle Check if they have 2.5ghz and 5ghz WiFi. If they dual as in have both, try connect the logger at a distance away from the router, heck put a box over router and dongle so that only the 2.5ghz is seen.
            5ghz will not work with the dongle
              #51
              I thought about what you are saying, however I overlooked it because we have ASC's on site, they sometimes become a challenge when there is a dual band router. Normally the network with a 5g at the end pops up for you to connect devices and I didn't see it. It is certainly something I will check today.
              The plan today was to switch off all the mesh WiFi units until their is only one unit, then attempt to connect again and see what happens.
              This stuff can get frustrating, simple things like a capital letter in a password or as you mentioned dual band broadcasting, throw in a mikrotik router and you can waste many hours trying to do something that should be one click of a button.
                #52
                We still havent resolved the issue.
                The sytem is sort of back online, but seems to drop or indicate that it is off line.
                It seems to be a combination of a mesh network (we had the same issue with the solar asssitant software conencted to a mesh network), SSID, bandwidth and what ever it is that is going on in the network. I am not an IT person, but I will figure it out, I always do.
                • Dylboy
                  • Jun 2020
                  • 777
                  #53
                  What is ASC sorry ?
                  And yeah switching off the mesh should help and hope you won
                  I'm now trying to setup a solarman dongle on a deye and struggling. Something that should be quick is now another day I need to find time to go there and the client be there too to set up. Want to try get him to do it
                  • Dylboy
                    • Jun 2020
                    • 777
                    #54
                    Quick one, make sure the static IP is NOT ticked, I and a dongle go down after about 3 months and then there was a wave of people having same issue after an update and if you and ticked static it have issues and that was the only site where I had ticked it.
                    Before I could test I had already swopped it and worked great.
                    It was the Sunsynk data logger.
                    That may help as well
                      #55
                      IF it was a Sunsynk dongle, I could talk yout through it on the phone I have done it so mant times now. Just watched a video on how to set it up, looks pretty much the same as the sunsynk.
                      Like anything you just need to do it a couple of times and anyone can do it. My problem is that I deal with so many different projects, from silly inverter installations, alarm system and CCTV which fall in pretty much the same catorgory, a couple days courses and you are a master, to more complex sytem automation and stuff like that.
                      This is why I say that technical support is critical for me, I have learnt to find the right person to speak to other you just waste the cusoters time and money. I am stil trying to find that perosn at Sunsynk, at the moment we still going around the world trying to get answers to questions.
                      ASC Astute smart controller.
                      What is ASC sorry ?
                        #56
                        The dreaded Sunsynk app, the one that doesn't show you what is happening in real time. It cant its just a snap shot.
                        There is way too much info on the main page, I hear a lot of complaints about how confusing the information is on the main page, and do you really want all that data in your face when you just want to see the dots moving.
                        I beleive they should make a simple front page with minimul data, then if you swipe the page to the left all the other stuff should load. Most customers just want to see if the grid is switched on (here in SA) and the state of the battery, and maybe the weather to see if the panels should be prducing power. All that other data most cusotmers have no interest and have no idea what its all about. It is viewed as clutter (much like all the adverts on this forum when you dont have adblockers setup) and more annoying than adding value.
                          #57
                          Good news, there is an update for the Sunsynk app.
                          I see they are going to start a series of training videos. Lets hope they take the technical support queries and build the videos on the queries flooding their call centre. Iron out the issues with the permanant bond, update the drawings used in the manuals and create valuable content, not just step by step content that is already in the manual. Yes, we have all read the manuals ... NOT. I prefer to take 10 hours trying to figure it out then 3 minutes to solve the issue by reading the manuals.
                          It would be good to see examples of using the system mode, I know it all in the manuals, we all know it is all in the manual, it would nice to see real life examples of ways to manage the system, especially with regards to how to save money on your elctricity account by managing the solar and batteries. How to use the solar to run the load and only the balance to charge the battery.
                            #58
                            Some good news...The issue with the app going off line seems to be resolved.
                            The green light stayed on all the time however everytime I went to check if everything was ok, the site would be offline.
                            I still havent had any feedback for technical support, so I decided to try fix it myself, the unit had a firmaware update a week ago.
                            First I waited till the site was online, then went to equipment, gateway, tapped on the 3 dots then tapped on unbind.
                            Did a factory reset, then pulled the dongle out the inverter and shutdown everything.
                            Fitted the dongle back in place and started switching on everything, waited for the normal light and adjusted all the seetings back to where they were (I need to save it to a file so that I can just upload to the site).
                            Went to networks and found the EAPXXXX and tapped, then off to chrome, tapped 10.10.10.1, scan the network, found the network, password and bingo, success.
                            Everytime I checked today, it was online
                            • JamF
                              • Mar 2023
                              Please assist
                              Have two sunsynk 5kw batteries in parallel. Recently, despite the system showing 100% SOC, the leds on one battery lights up to 4/6 whereas the other battery is lit up 6/6.
                                #60
                                Which Sunsynk batteries, the IP 65 or standard batteries?
                                Did you set the dip switches correctly (standard batteries, no dip switches on the IP 65 batteries) or switch on the batteries in the correct order if you have IP 65 batteries?
                                Did you install the coms cable in the correct ports?
                                How did you wire the battery cables, parallel or casacade parallel?
                                Have you checked the battery communication, the IP batteries have a full description ?
                                I am experiencing issues with batterries dropping to 99/98 % when the batteries are set for 100%
                                Originally posted by JamF
                                Please assist
