Ceiling insulation effect on electrical workI'm looking at having some cellulose insulation put into my ceiling. Basically they spray the stuff all over which results in good coverage. From an... |
Thread Tools | Display Modes |
#1 |
just me
![]() Join Date: Jun 2006
Rep Power: 10 ![]() ![]() ![]() |
From an electricians perspective, what impact can they have on the workability, and what should they do to make sure that everything is still up to COC spec? Also, what is your experience of this type of insulation versus Aerolite or Isotherm? |
#2 |
Rep Power: 0 ![]() |
I can honestly tell you , that any insulated roof is " hell " to work in.
The spayed stuff , you're talking about covers all wiring , junction boxes, ect. Point is , it's i'd prefer to work in an uninsulated roof. The reality is that most roofs are insulated. so , go ahead and insulate your roof. I wouldn't go for the spay though. ( This is just an opinion ) : It's like covering your ceiling with an inch of dust . |
#3 | |
Quote:
#4 |
![]() Join Date: May 2006
Rep Power: 28 ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Reading that, a thought occurs...
How much effect would ambient temperature have on the maximum current rating of the cable? |
#5 |
Ambient temperature
According to SANS the ambient temperature of 30 degrees celcius and a cable opertating temperature of 70 degrees celcius is taken into account when rating the cables.
#6 |
![]() Join Date: Oct 2007
Rep Power: 4 ![]() ![]() |
i would say so long as it doesnt interfere with the integrity of the electrical installation it shouldnt be a problem...ie if there are no exposed wiring downlights etc in the roof there shouldnt be a problem.
the ambient temperature should be less because the wiring will be under the insulation the heat will be above the insulation...as mentioned this stuff is a nightmare for electricians...especially the pink aerolite...just my opinion i could be wrong. |
#7 | |
Quote:
My thinking was going something like this: First, roof temperatures can get to 50 degrees celcius in summer, if not more. From there, insulation might protect the cabling from ambient temperature, but you are also losing the ability to disipate heat generated by line resistance. There must be fairly aggressive safety tolerances built into these calculations though, surely? |
#8 |
![]() Join Date: Jan 2010
Rep Power: 1 ![]() ![]() |
The reason the cable gets derated in an insulated environment isn't because of the ambient temperature, it's because it's ability to loose heat is reduced. The cable has a resistance which generates heat along its length when current flows within it, this heat will cause higher temperatures if the cable is insulated than if the cable is in free air.
#9 | |
Rep Power: 1 ![]() |
Quote:
#10 |
![]() Join Date: Oct 2009
my 2 cents worth....
-A cable rarely runs at its maximum CCC. This is even more the case if an installation is planned correctly and laid out correctly. Keep in mind that the heavy residential items on a non-dedicated S/O circuit like tumble driers, washing machines, garage Sockets (welding machines) does not run for very long, especially not all together. Maybe you'll run your washing machine and tumble drier together, and maybe you'll do that for 6 hours during the day but the fact is that even they draw current intermittently in their cycles. -If you talk to the cable manufacturers they will give you the actual current carrying capacity of their manufactured cables. SANS in my mind sets an industry standard since not every second guy will phone Aberdare or who-ever to request their amp ratings etc. |
| Did you like this article? Share it with your favourite social network. |
| Tags |
| ceiling, electrical, insulation |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Should we really be at work? | duncan drennan | Business Management Forum | 1 | 04-Jan-07 09:36 PM |
