Simple ways to improve your energy efficiency
  • duncan drennan
    • Jun 2006
    • 2642
    I just read through this blog post about halving your electrical consumption, which made me think that it would be worthwhile starting a list of simple, cheap, and easy ways of reducing your energy consumption. Here is a list of some of the things he did (in Australia)
    • Conduct an Energy Audit to sniff out the culprits. Many surprises here, both good and bad.
    • Used a Floatron to dramatically lower pool energy requirements.
    • Switching off at the wall standby power loads at night, like TVs and PCs. Grumble. I wish there was a box that could do this for me, or that beeped in my kids ears when they forget.
    • Swapped out nasty incandescent light bulbs for compact fluorescent (CFLs).
    • Swapped out nasty halogen downlights for LED downlights.
    • Encouraged the use of laptops (20W) rather than desktops (90W).
    • Where possible use my laptop on mains rather than battery power, as I have read the charging/discharge cycle is only about 50% efficient
    • Placed my home office equipment on a separate power board than can be switched off at night, while leaving my server running. Previously I just left everything on.
    • Promised my 9 year old son an extra $1/week if he remembers to switch his PC off at the wall every day. Good training, teaches him “the value of energy”. I figure that energy efficiency is going to be a much bigger issue in his life than mine.
    He also sorted out his insulation, and changed the glass in his windows to a better insulating glass. Also have a look at the results of his energy audit - it may be illuminating.
    In my mind we are in the middle of an energy crisis that the government is powerless to do anything about. Social change is required. Each of us need to change. Think about - make a few small changes, have electricity at all hours of the day. It makes a lot of sense. So start changing now. Do it for yourself.
    Please add your energy saving tips to this list.
  • murdock
    • Oct 2007
    • 2346
    you need to change the attitude before you can start saving the energy...i always hear people saying but we pay for our electricity...and look at all the lights left on in the show rooms at the car sales houses...and look at the street light left on all day...and look at all the lights in the car parks in the shop centres...etc...etc...etc...
    we need to start with the attitude...then the people who have so many lights... like the new revamped edgars you need sunglasses when you walk into the store some fool must have been getting commission for the brighter the shop the bigger the commission... and all they are doing is burning more energy than needed...if there was a little thought put into the design they could have used more energy efficient light fittings...and put a system in place that at certain times there is no need to have 1500 light fittings burning in a parking lot with 1 car parked in it.
    so it is going to take a totally different mind set to solve these issues...and everyone from the man on the street to the engineer who designs the building and the control system of the buildings to solve these problems.
    • duncan drennan
      • Jun 2006
      • 2642
      It is quite interesting to see this whole energy crisis playing out at the moment. Two years ago Cape Town was in darkness for quite a while, and the general attitude was changed significantly by that. Now we just have a national problem. Sometimes pain is the only way to change ingrained attitudes. Things are changing. Now we just need to provide people with ways of helping save energy.
      • irneb
        • Apr 2007
        • 625
        Here's the tips from Eskom themselves (for residential use): http://www.eskomdsm.co.za/resdsaving.php
        And then fro commerial (http://www.eskomdsm.co.za/commercialsaving_a.php) and industrial (http://www.eskomdsm.co.za/industrialsaving_a.php).
        Then some international sites regarding power saving appliances & tips:
        • rohor
          • Jan 2008
          • 6
          I dont believe that the trick is saving electrical consumption in general, because if it is "saved" at the wrong time, there is no benefit.
          The trick is to reduced demand at peak times.
          • duncan drennan
            • Jun 2006
            • 2642
            Adjust your air conditioners for more efficient operation. Eskom estimates that HVAC (heating, ventilation, air conditioning) makes up 15% (5400MW) of SA's peak consumption.
            The best (short term) solution is to turn off you air conditioners! Check your building insulation and make sure you are not trying to cool (or heat) a sieve for hot air.
            If turning off your aircons is not an option, then at least run them more efficiently. In the mornings use the fan to circulate cool air from outside into the buildings. As the day heats, turn them to cooling, but try to run them as close to the outside temperature as possible, and always within 10º of the outside temperature. Ensure that aircons are turned off (or adjusted) when the building starts to empty. (read the complete details on Eskom's HVAC page)
            I was quite interested to see that China has energy police who enforce that aircons are no lower than 26ºC!
            • seymour7
              • Feb 2008
              • 7
              Interesting replies. To be honest, I haven't thought much about saving electricity, but I am definetly going to start... TODAY! I'm sure that just by saving electricity in your house we can help solve this problem.
              Eskomplain.co.za
              --When enough is enough!
              • Chatmaster
                • Aug 2006
                • 1065
                Welcome Seymour7!
                Love your blog, I will definitely frequent it!
                • seymour7
                  • Feb 2008
                  • 7
                  Originally posted by Chatmaster
                  Welcome Seymour7!
                  Cool, the more people the better. I love this forum too. That reminds me. I'm not too sure if I'm allowed to advertise this here, but I'm gonna need some more writers for my blog, you know, to keep it as active as possible. If anyone is interested in being an author/writer for www.eskomplain.co.za PM me. Maybe you, Chatmaster?
                  Eskomplain.co.za
                  • duncan drennan
                    • Jun 2006
                    • 2642
                    I've been really happy to see that both Pick n Pay and Checkers have pamphlets and marketing campaigns around saving energy.
                    You can check out Pick n Pay's really good energy saving tips on their website, and take the "power pledge".
                    • greenpulse
                      • Aug 2008
                      • 3
                      Save energy with clever software
                      We are all constantly looking to save energy. Eskom threatens us all all the time with the word "loadshedding" and tells us all to cut further and further.
                      As a result of this I looked at my office and realised my biggest energy drain was my PCs. Yes I had sleep mode and so called "power save" fucntionality but could I go further.
                      The answer was YES.
                      I was introduced to a Slovenian Company and subsequently signed up the rights for GreenPulse in South Africa. www.greenpulse.co.za
                      GreenPulse is saving me already. My bill dropped quite a bit once I installed it on all my PCs - only 10. But the savings are felt and to be honest staff did not even notice the change. They simply left their PC on as before and GreenPulse did the rest.
                      Try it.
                        • 22816
                        Question: Can't this be achieved by configuring your display settings on Windows XP?
                        • greenpulse
                          • Aug 2008
                          • 3
                          No, saldy it cannot.
                          XP and Vista cannot control the fans, LED's etc.
                          GreenPulse also provides swift reboot - sleep mode as standard is slow and painful, a reason why many choose not to use it. The reboot also requires a surge of power whereas GreenPulse eliminates this.
                          Try GreenPulse for free www.greenpulse.co.za
                            • 22816
                            Maybe I'm just too used to laptops where hibernate is an available option.
                            • greenpulse
                              • Aug 2008
                              • 3
                              Even Hibernate is not the best thing. GreenPulse improves battery life. Hibernate is slow to come out of and eats power when doing so. Green Pulse prolongs autonomy and battery lifetime. The program detects when your laptop is not plugged in, and it accordingly reduces the battery usage.
