Results 1 to 4 of 4
Thread: Low voltage down lights and ceiling earth bar
    Jul 2011
    Boksburg
    Just to get back on the transformer subject that was discussed recently,
    So any transformer inside the roof should be mounted due to heat etc etc etc,but what if its the new type 50W completely plastic transformers,surely theres no heat involved exept from the globe itself which obviously is the correct distance away from the transformer,should this transformer still be mounted???
    Then another thing,what is this thing i hear where every property has to have a earth bar in the ceiling with a completely seperate earth to the board,is this true???
    Quote Originally Posted by ColinK View Post
    There's mixed views on whether a transformer should be mounted and there's good reasons for the arguments on both sides. I would decide on a case by case basis. If there's insulation material above the ceiling then I would mount them securely. Electronic transformers often produce less heat but they require good ventilation regardless.
    It is regulations that an earth bar be installed for use by other services and you would normally provide the earth for the TV antenna from there.
    All these requirements and more are contained in the SANS0142 codes which are available from here for R406.00.
    Jul 2008
    Germiston, South Africa
    220 volt converted downlight fitting
    Today I came across this version of a converted downlight. I do not think it is compliant. What do you think?
    What do you think?
    I think you have a problem with your image link
  1. Touch Voltage
    By shuudeni in forum Electrical Contracting Industry Forum
    Last Post: 10-Feb-11, 05:46 PM
  2. Mains voltage logger
    By duncan drennan in forum Technology Forum
    Last Post: 05-Feb-11, 03:33 PM
  3. Difference between: Power factor correction, Voltage regulation and Voltage stabisizi
    By BigRed in forum Electrical Contracting Industry Forum
    Last Post: 08-Feb-10, 09:29 PM
  4. Earth hour
    By Dave A in forum General Chat Forum
    Last Post: 04-Apr-09, 11:38 AM
  5. Google Earth
    By Faan in forum General Business Forum
    Last Post: 30-Jul-08, 08:52 PM
