Results 1 to 10 of 10
Thread: How do I print a sales order with bin numbers in Pastel Partner?
    Apr 2011
    Jhb
    Question How do I print a sales order with bin numbers in Pastel Partner?
    Hi,
    How do you print a sales order out of Pastel Partner that includes the bin numbers on the document? This could then be used as the picking slip for packing purposes. Ideally, I would like to print this in bin number order, so that the packer could start at the first bin number going numerically through to the last bin number, without jumping back and forth.
    Pastel Partner Help file says that you can customise the document to print the bin number details, but I don't know where to switch this option on.
    Please help.
    Thanks!
    Apr 2011
    Jhb
    Ok, so I customised the document in forms designer - Thanks for the tip, Neville, I appreciate your help!
    My picking slip now have the bin numbers on the document. Can I sort items by bin number when printing the picking slip, so that the items follow in order?
    Morningside, Durban
    No, you can't - the line items on the document will print in the sequence in which you captured them.
    There are work-arounds though.
    One option is to export the sales order into a csv file, and then reorder the line items by bin number after opening the csv file in Excel and then import the csv file back into Pastel. You will need to delete the original sales order though.
    Let me know if you need help with this.
    Sent from my BlackBerry 8520 using Tapatalk
    Apr 2013
    Print bin number on picking slip.
    Hi Neville.
    Could you tell me how to print bin numbers on picking slips or would it also appear on the proforma when it is added in forms designer?
    Paul Millard
    Quote Originally Posted by Neville Bailey View Post
    Jan 2018
    Windhoek
    Bin numbers only on sales orders
    Quote Originally Posted by J7J View Post
    Hi,
    Please help.
    Thanks!
    Hi,
    What is the file name in form designer for sales order?
    Please assist
    Morningside, Durban
    Quote Originally Posted by Mariajs View Post
    Hi,
    Please assist
    CORDRSP.ENG (if you are using plain single sheet paper - substitute the "SP" portion to suit your paper style).
    Jan 2018
    Windhoek
    I want to add bins only on the sales order to use it as a picking slip
    Jan 2018
    Windhoek
    Thank you, will try it out!
  9. #9
    Jan 2018
    Windhoek
    Bin nr on sales order
    Hi Neville,
    I file save as one of our form in form designer with the name CORDRSP.ENG. add the bins but the lay out is the same as what the invoices is set up.
    I looked if there is a file name mentioned above as you gave it to me, but I don't see anything? That is why I file save as.
    Can you guide me with more details details please.
    We have 4 file names, CSDOCODFSP, CSDOCSP, CSMTHPDFSP, CSMTHSP. If you change the invoices everything under that docs is changed e.g sales order.
    Kind regards,
  10. #10
    Morningside, Durban
    Make sure that you save the sales order form file as CORDRSP.ENZ and save it into the company folder.
  1. [Question] Importing Sales Order detail into Pastel Partner
    By J7J in forum Accounting Forum
    Last Post: 19-Feb-14, 11:49 AM
  2. [Question] Pastel Partner - Indication of GP% when doing quote
    Last Post: 24-Jun-11, 10:00 AM
  3. Replies: 2
    Last Post: 14-Apr-11, 11:22 AM
  4. [Question] Pastel Partner
    By Goop in forum General Business Forum
    Last Post: 15-Aug-10, 06:58 PM
  5. [Question] Help with Pastel Payroll Partner
    By celly007 in forum Tax Forum
    Last Post: 17-Sep-09, 10:25 AM
