Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 106
Thread: Installation of 220V downlights
  1. #21
    Feb 2011
    SANS 10142-1:2009
ID:	1874Click image for larger version.
  2. #22
    There's a small matter of length of downlighter tails vs exposed wiring floating around at the back of my mind at the moment as I'm reading this.
    Quote Originally Posted by 123 View Post
    Pse Elaborate: Me
    Cancel that. It's been the length of mains side transformer tails that we've found as a pretty common issue on new installations.
    Sorry for the confusion.
  3. #23
    Oct 2007
    light points and open/exposed wires...this is another who thread on its own?
    connecting 2 pieces of twin&e into the primary side of the transfomer?
  4. #24
    Comments anyone?
  5. #25
    Oct 2007
    better than most i see on a daily basis...i have just finished a...what started out as a little job just to fit 3 lights and connect an ectractor fan....turned into a total rewire of the kitchen...and as the customer always says....but i dont understand it has worked for years....the kitchen was done years ago and the kitchen people got their electrician to wire all the lights and plugs.
  6. #26
    Gold Member Sparks's Avatar
    Dec 2009
    Aaaaah... the things we see....
  7. #27
    Mar 2011
    Western Cape
    Installation of 220v downlights
    Is this legal? 12v downlight fitting with 220v globe, 220v porcelin globe holder with 150mm heat resistant leads connected to 16A connector strips. My supply is 220v, 1mm t&e connected to the connector block. Leads are +- 150mm away from light fitting. Also: Draw box in roof, leads going to lights and supply from D/B. Lead going down to 2 way switching, using 1mm t&e. If earth is insulated on both ends, can it be used as a life feed?
  8. #28
    Quote Originally Posted by phillip View Post
    I'm confused, if it has a 220v globe then it's a 220v downlight. Why do you say it's a 12v downlight fitting?
    This is illegal on more than one account. Do not use the earth wire of any cable as a live, switched live or a neutral. If somebody gets injured whilst working on or using this installation because the regulations have not been followed you might well find yourself in court on a culpable homicide charge.
  9. #29
    Sep 2010
    cape town
    i see a lot of 12 volt fittings used with 230 volt lamps .it doesnt have the built in lamp holder. some electricians earth the 12 volt fitting and use the porcelain 230 volt lamp holder. the connection of the leads is in a box,but the leads are still exposed the same as the 12 volt lampholder.therefore i fail it anyway.
    you can buy this contraption that fits on to the 12 volt fitting with a built in lampholder and connection box.
    as andy says using the earth wire as a live conductor is highly dangerous and illegal.
  10. #30
    Dec 2009
    When I find an earth wire being used as a return my prices double for "danger-pay", (what else is wired like that?). I show the owner exactly what the problem is and scare all the crap out of them with a very detailed descripting of how their whole family could be wiped out trying to help the grandchild being electrocuted. By the time I am done with them they rather sit in the dark, until I can do the repairs, than touch a light switch.
  1. Electrical Installation Costs
    By Tracsec in forum Electrical Contracting Industry Forum
    Last Post: 28-Jul-22, 05:38 AM
  2. [Article] New electrical installation regulations
  3. Zen cart installation tips
    By garthu in forum Technology Forum
    Last Post: 13-Aug-10, 11:55 AM
  4. Who may work on an electrical installation?
    By douw in forum Electrical Contracting Industry Forum
    Last Post: 16-Apr-10, 11:57 AM
  5. new installation
    Last Post: 18-Feb-10, 01:34 PM
