Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Excel Help please
    Full Member greghsa's Avatar
    Aug 2010
    Excel Help please
    Excel fundi's please help.
    I have an Excel pricelist worksheet (.xls Excel 2003, 300 lines) with the following columns:
    Code Price1 Price2 Price3
    I also have another worksheet(.xls Excel 2003, 2000 lines) with the following columns:
    Code Description
    I want to modify first worksheet or create a third worksheet that will have:
    Code Description Price1 Price2 Price3
    Copy and paste or sorting will not work as different number of lines.
    All codes in first worksheet are in second worksheet.
    I would like excel to look for same code in different worksheet and pull the description .
    Hope this makes sense. Any ideas would be appreciated
    Mar 2010
    Talking
    Quote Originally Posted by greghsa View Post
    Code Description
    Ok, here is a demo
    Code:
    Set up Book1 Sheet 1 as follows: (Save it and keep it open)
    code	price1	price2	price3
    code1	price1_1	price2_1	price3_1
    code2	price1_2	price2_2	price3_2
    code3	price1_3	price2_3	price3_3
    code4	price1_4	price2_4	price3_4
    Set up Book2 Sheet 1 as follows: (Save it and keep it open)
    code	descr
    code1	descr1
    code2	descr2
    code3	descr3
    code4	descr4
    Set up Book3 Sheet 1 as follows:
    code                    desr	                                           price1	                 price2	                         price3
    =+[Book1.xls]Sheet1!A2 	=VLOOKUP(A2,[Book2.xls]Sheet1!$A$2:$B$5,2,FALSE)   =+[Book1.xls]Sheet1!B2       =+[Book1.xls]Sheet1!C2         =+[Book1.xls]Sheet1!D2
    =+[Book1.xls]Sheet1!A3 	=VLOOKUP(A3,[Book2.xls]Sheet1!$A$2:$B$5,2,FALSE)   =+[Book1.xls]Sheet1!B3       =+[Book1.xls]Sheet1!C3         =+[Book1.xls]Sheet1!D3
    =+[Book1.xls]Sheet1!A4 	=VLOOKUP(A4,[Book2.xls]Sheet1!$A$2:$B$5,2,FALSE)   =+[Book1.xls]Sheet1!B4       =+[Book1.xls]Sheet1!C4         =+[Book1.xls]Sheet1!D4
    =+[Book1.xls]Sheet1!A5 	=VLOOKUP(A5,[Book2.xls]Sheet1!$A$2:$B$5,2,FALSE)   =+[Book1.xls]Sheet1!B5       =+[Book1.xls]Sheet1!C5         =+[Book1.xls]Sheet1!D5
    Just substitute your book & sheet names, then correct your columns, rows & cell range for the vlookup.
    Look carefully at the cell range, return column and exact match specifyer in the vlookup.
    Cell range is top left where code starts and right bottom where description ends.
    Return column is 2 because column 1 is the code to be looked up and column 2 is the description to be returned.
    Exact match is set to FALSE otherwise it will return the nearest match which may not make sense. It is better to be able to convert a missing description to "MISSING DESCRIPTION" rather than a incorrect value
    You can set up the missing description check as follows:
    =IF(ISNA(VLOOKUP(A6,[Book2.xls]Sheet1!$A$2:$B$6,2,FALSE)),"MISSING DESCRIPTION",VLOOKUP(A6,[Book2.xls]Sheet1!$A$2:$B$6,2,FALSE))
    Remeber to correct all the cell references
    ...and there you go
    ~GS Elevator
    greghsa (14-Aug-10)
  4. #3
    Aug 2010
    Quote Originally Posted by adrianh View Post
    Ok, here is a demo
    Code:
    code	descr
    code1	descr1
    code2	descr2
    code3	descr3
    code4	descr4
    ...and there you go
    I new it would have a VLOOKUP in it, but would never have cracked it myself. Thank You
  5. #4
    Sep 2012
    Hi Guys
    Have a question on excel:
    I have a created a table on excel with coloumns and rows.
    I effectively need to find the sum of a criteria that is required in Coloumn A and row A ie
    A B C D E F G H
    1
    2
    3
    4
    5
    6
    7
  6. #5
    Mar 2010
    You need to explain what you need far more clearly than that...either that or I am to doff to figure out what you are on about.
    ~GS Elevator
  7. #6
    Sep 2012
    Hi, Apologises the thread uploaded before I finished the Q:
    I have an array of data. In the top row , row 1, I have the following consistent cell descriptions
    T1Actual T1Budget T1Prior T1Actual T1Budget T1Prior
    In the first coloumn, col A i have the following data
    A8
    A3
    A8
    A8
    A6
    What i am trying to calculate is the sum of all the points in the table where T1Actual and A8 intersect.
    The 3 parts of the formulae are effectively
    Table A1: Z50
    Criteria 1 : Row1, "T1Actual"
    Criteria 2 : Coloum A, "A8"
    Now sum where all these points meet in the table.
    Hope this make more sense
    Mar 2010
    Why don't you just sort all the data by t1actual. Doing so will group all the A8's together making it easy to sum.
    ~GS Elevator
  9. #8
    Sep 2012
    each 3 refrences refers to a month in 2012 ie Jan then Fe then march etc etc
    T1Actual T1Budget T1Prior T1Actual T1Budget T1Prior T1Actual T1Budget
    Jan 12 Jan 11 Feb 12 Feb 11 Mar 12
    T1 T1 T1 T1 T1 T1 T1 T1
  10. #9
    Mar 2010
    Look, there is another way of doing it. What you would do is to write a little subroutine in VBscript that will run through your data collecting and summing the figures that you need.
    I find it very difficult to picture your data so its hard to write the program.
    PM the file or a sample set of the data to me and I'll show you how to do it.
    ~GS Elevator
  11. #10
    Sep 2012
    See attached example
  1. Pastel Partner to Excel Auto mapping
    By tyrone k in forum Technology Forum
    Last Post: 11-May-09, 04:59 PM
  2. [Article] Nifty Excel spread sheets
    By IanF in forum General Business Forum
    Last Post: 05-Dec-08, 12:14 PM
  3. SASOL & EXCEL in trouble
    By Sieg in forum General Business Forum
    Last Post: 21-Oct-08, 11:17 AM
Tags for this Thread
