Results 1 to 3 of 3
Thread: Costing per Network point
    Full Member Cpt Chaos's Avatar
    Jun 2010
    Hi guys,
    I need some input from the bit more experienced guys working in the IT Industry. I've got a client that I need to give a rough estimated quote on the cost of installing a new network from scratch and also prefers CAT6 cable to be laid.
    Now the problem is that I usually charge a fixed price per hour labour and then add the cabling and all the extra's to the price for an entire installation after measuring up the office building, but as you have guessed this client needs a quote per point of installation. What is the best way forward here do I keep my hourly labour charge the same or do I adjust it. The cost of the wiring per point will also be worked out on x meter of wiring but when the point is further away charge y per meter extra
    Hope someone can help me.
    Thanks in Advance
    May 2007
    Johannesburg, South Africa
    We charge R350 per point, upto 100m. CAT6 is more expensive, and if it's shielded CAT6 the labor is also more intense so I would charge R400-R500 per point respectively.
    This is the norm in cable installations, both for networks, CCTV & alarms
    Cpt Chaos (14-Jul-10)
  4. #3
    Jun 2010
    SoftDux thanks a lot, that got me going. Quote is done and dusted and sent of to my client.
  1. MLM - Very Possibly the perfect Business
    By thebanman in forum MLM Industry Forum
    Last Post: 13-Jun-09, 09:28 AM
  2. Network, one person at a time
    By duncan drennan in forum Entrepreneurship and Business Management Forum
    Last Post: 09-Jun-07, 01:18 PM
