Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: strange hard drive noises
    Oct 2008
    my computer has become increasingly slow over the last month or so, and my hard drive has been making strange sounds lately. just want to know if my hard drive is breaking or if there could be something else wrong?
    Gold Member daveob's Avatar
    Feb 2008
    Amanzimtoti
    Backup your data and make a Ghost copy of the drive NOW !!!
    You can come back and Thank us for the advice later.
    Silver Member Norri's Avatar
    Mar 2008
    Centurion, South Africa
    Definitely what Dave said! It can take months or it can take minutes but, one day, you will wake up and all your data will be gone.
    Make the backup and replace your hard drive asap.
    Norio De Sousa - Done4U.co.za (Web Design & Copywriting)
    Maxiware CC Reg no. 2000/048244/23 (Maxiware CC)
    Gold Member Chrisjan B's Avatar
    Dec 2007
    GEORGE
    Quote Originally Posted by Norri View Post
    I STRONGLY AGREE!
    BOVER Technologies
    Gold Member Dave S's Avatar
    Jun 2007
    Randburg
    Ditto, this is a typical "FAILURE IMMINENT WARNING". Make an image NOW!!!
    Maybe gecko's hard drive died and that's why he's not back.
    (Or she I guess - you never know nowadays )
    Oct 2008
    hey im back!
    thanks for the help your asap's really did help. my hard drive crashed last week and i had to get it replaced, copied everything and now i still have all my valuables that were on there, phew thank goodness.
    why did it crash though, did i over use it?
    the guy that fixed it said i had dropped it, but unless it myseteriously fell when i was not around, it couldnt have been that.
    just me duncan drennan's Avatar
    Jun 2006
    Quote Originally Posted by gecko View Post
    There are LOTS of reasons a hard drive could fail. Due to the noise it was making I would guess that the bearing probably failed. Hard drives get hot and there is a fair amount of mechanical strain on the moving parts.
    Something as simple as the failure of a capacitor on the power supply could also stop a hard drive from working, but that wouldn't have warning noises. The chances of the electronics breaking (under normal conditions) are lower than the chances of the mechanical bits failing.
    [SIGPIC]Engineer Simplicity[/SIGPIC]
    Turn ideas into products | The Art of Engineering blog
  9. #9
    Oct 2008
    hmmm ok so if it was a heat issue do you think its because i keep my computer running 24/7 or maybe my fan is broken or not working properly?
  10. #10
    Dec 2007
    GEORGE
    Nowadays I am installing a Hard drive cooler on mostly all hard drives - it brings down the temperature of the hard drive down with about 10 degrees Celsius. In my box I have two 320GB 7200 rpm harddrives running at 31 degrees. I think the cooler you can make it run the longer it should last. It adds about R 90-00 to the cost of a PC. IMHO money well spent.
    Also a big case with fans in front and back will also help air circulation and will affect the temperature in the case.
    I would like to hear your opinions on the hard drive cooler.
    Thanks.
    BOVER Technologies
