Results 1 to 5 of 5
Thread: PASTEL - PROBLEM WITH BACKUP RESTORE PROCESS
    Mar 2016
    Centurion
    I have a problem restoring my backups. Have done it successfully on my hard drive and external drive.
    The error reads:
    There is a problem with the restore process. It could be caused by one of the following:
    The backup dis is not properly inserted into the selected drive.
    An incorrect backup disk is used.
    The backup disk is corrupt
    The hard drive is full
    An incorrect restore drive is selected
    Does anyone know how to solve the problem
    Thanks in advance
    Morningside, Durban
    I suggest that you bypass Pastel's restore process and do the following:
    Close Pastel and then, in Windows, rename the existing company folder to something else. Then right-click the backup file (which is a zip file) and select Extract All - this will create a new company folder. Open the company folder and look for a file named backup.txt and delete it. Make sure the new company folder is in your Pastel14 folder (where the original company was located).
    You can then open the company in Pastel.
    Jul 2016
    Namibia
    Hi Neville,
    I'm a newbie on the the forum and I'm not sure where to post my questions. My apologies for using another members thread to post my questions.
    I have 2 questions.
    1. How do I process an invoice with import vat in pastel?
    2. What type of expenses is a Jerry can/ fuel container? The company purchases these only when they are needed, which can be once/twice in 2 years. I'm sure I can't allocate it to the fuel expense account. So do I create an expense account for it? And I kind of feel that it might be an asset too. Kindly advice
    Anna
    Morningside, Durban
    Quote Originally Posted by Tuna View Post
    Create a GL line item on the invoice for the import VAT amount, and use the VAT code 100%. It does not matter which GL code you use, as the entire amount will be automatically allocated to the VAT Control Account, due to the 100% VAT code.
    It depends on the reason for the purchase of the cans, and how they are used. If they are used to contain fuel that is then sold, then I would allocate the purchase to something like consumables/packaging, for example.
    Jul 2016
    Namibia
    Thank you. We use the cans to store fuel for the generators and compactors that are used on our construction sites. So Packaging it is.
  1. Pastel Express V11.2.1 Backup Error 507
    By Sanni D in forum Business Finance Forum
    Last Post: 17-Feb-16, 12:42 PM
  2. pastel payrol restore backup
    By anene in forum Accounting Forum
    Last Post: 04-Nov-15, 10:35 AM
  3. [Question] Pastel Backup Error ((103)~PVSW~.LOC
    By SeanE in forum Accounting Forum
    Last Post: 18-Mar-15, 04:25 PM
  4. [Question] Backup In Pastel Partner
    By Tat in forum Accounting Forum
    Last Post: 11-Jan-14, 08:30 AM
  5. Replies: 2
    Last Post: 14-Apr-11, 11:22 AM
