Results 11 to 20 of 22
Thread: Rechargeable Light bulbs
  1. #11
    Bronze Member Xplosiv's Avatar
    Dec 2013
    Oudtshoorn
    This sounds very interesting. Please keep us updated on stocks and how it works. I've seen similar, but they have a switch on the bulb itself you need to activate. They don't come on automatically.
    Do you deliver and if so, at what cost? Doubt they'll be available in my small town.
  2. #12
    How does the bulb know the difference between a power failure, and normally switching the light switch off?
    I have worked it out in my mind, just want to make sure that I am on the same page.
  3. #13
    planet earth
    I would be very concerned and stay very far away from it, if it works with the earth of the switch...eeeeeish.
  4. #14
    planet earth
    I know why I am not rich, because i dont rape the gulible public
  5. #15
    May 2015
    hahaha... oh snap why did I assume your name is Dave
    But Okay sure, I will keep you posted on when the shipment arrives.
  6. #16
    May 2015
    I really do not know how it works, we were just guessing it works on the earth line. Because we do not know how the bulb picks up the power is off - the eart line was just a guess. We switched our power off on the mains at the board and the bulb would not go on but as soon as we experienced load shedding it would come on. strange I know and still cant really explain to you how it knows
  7. #17
    Quote Originally Posted by JLK View Post
    Yep just as I guessed. There is some electronics inside the globe, which is powered by the rechargeable battery. This electronic circuit measures the line impedance when the power is off. When you switch off at the wall switch, the LN line will show a very high impedance as there is very few loads on the same circuit, however when there is a power failure, the line impedance is very low because it probably measures the transformer impedance, so the electronics then switches the light on.
  8. #18
    Mar 2013
    Had enough
    it works ians ... I've see them .....
  9. #19
    Hmm, call me a cynic but I'm not convinced . I guess it's possible in theory but in practice it would need to be constantly injecting a test signal into the supply and it would need considerable intelligence built into it. There's a couple of other issues as well such as during a power outage it would likely only 'see' the other loads connected to the installation(s) rather than the secondary side of the supply transformer. The impedance of the other lamps, transformers, ballasts, drivers or PSU's on the same switch circuit would also be an issue because this impedance would remain regardless of the circuit being switched on or off. Also if there was more than one of these things on a supply transformer they'd likely interfere with each other unless they all use a unique test signal.
    I'm just thinking outloud here and I'll be the first to say that anything's possible so I'd be very interested if someone would purchase one and promptly reverse engineer it to satisfy my curiosity and let me know how it works
  10. #20
    May 2015
    Another confusing thing is the fact that it works on a bed lamp which is not plugged into a wall... It comes on and off with the lamps switch. Little mind boggling to the average person.
  1. [Question] Why do bulbs blow all the time?
    By Houses4Rent in forum Electrical Contracting Industry Forum
    Last Post: 10-Aug-14, 08:36 AM
  2. [Question] Hi Bay Light Fittings
    Last Post: 24-Jan-13, 07:45 PM
  3. light fittings
    Last Post: 09-Aug-12, 11:04 AM
  4. [Question] Down Lighter Bulbs
    By AmithS in forum Electrical Contracting Industry Forum
    Last Post: 05-Apr-11, 08:53 PM
  5. [Question] Rechargeable Batteries - Li-Ion?
    By irneb in forum Technology Forum
    Last Post: 27-Nov-08, 08:21 AM
